P1000 Fuel pump replacement
G
GaryZ
14
12
FL
Hello,
I was wondering if there are any pitfalls or tricks to installing a new fuel pump assembly?
My 2016 1000 died a few weeks back. It will turn over but it will not start. It stuttered a few times previously but a quick press of the gas pedal quickly remedied those instances.
One of my fellow lease members (automotive mechanic) looked at it over the weekend and determined the fuel pump was bad.
He removed the fuel pump and confirmed that there was power going to the pump and it was not working.
I'm looking to order the assembly soon and I was just wondering if there are any pitfalls or trucks to the install. Ie. priming, etc.
I'm certain someone here has done the install but my search did not turn up anything definitive.
Thanks.
Reactions: TimG
G
GaryZ
14
12
FL
Installed new Fuel pump and my machine is back to purring like a kitten.
I would definitely recommend ordering a new gasket to replace at the same time.
No priming required. I just turned the key on and let the pump run for 10 seconds and she fired right up. She stalled when I first pushed the gas pedal so I let her idle for about 30 seconds and then she was good to go.
Hope this helps.
