P1000 Full doors
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
So I'm thinking before winter I'm going to build some full doors. I want handles on inside and out was going to start with this latch anyone have other ideas what handles I could use A92e51e5f4cded038abd73dc0c7f19bf
So I'm thinking before winter I'm going to build some full doors. I want handles on inside and out was going to start with this latch anyone have other ideas what handles I could useView attachment 131993
That looks like a good option.. I can’t think of anything that would be any more affordable or practical.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Thinking blue will be fixed ,yellow hinged in original spot, purple will be lexan in frame and slide in and out yellow for easy removal. What do you think @CumminsPusher @Plumber32 @joeymt32 E5ee4f1ba969961bf292db8798809576
BWAF
BWAF
8,857
42,437
Carthage MO
The mini 2 point actuator would allow you to have a handle inside and outside
One forward and one up or down that's what I was thinking
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Southco makes a lot of latches like that. They call them Rotary latches.
R4 - Rotary Latches - Southco
It's always nice to know about places like this for various projects. Just like mcmaster carr, these types of sites sure come in handy. I'll have to add this one to the list.
Reactions: JTW
BWAF
BWAF
8,857
42,437
Carthage MO
Thinking blue will be fixed ,yellow hinged in original spot, purple will be lexan in frame and slide in and out yellow for easy removal. What do you think @CumminsPusher @Plumber32 @joeymt32 View attachment 132010
Dam you guys got no input for me ?
Reactions: CumminsPusher
321,218
Sorry buddy it didn’t notify me. Just noticed the thread.
The purple is easier to keep solid however it doesn’t need to go all the way up.
Everything else sounds good if you do have the upper slide off use tubes with a bit of slop so crap doesn’t slow your roll and have it secure under roll cage so it’s locked in when door shut. You probably were though. Quick bolt setup is solid too, I’ve got 3 short 10mm per door so upper comes off very quickly and no rattles.
Also try to recess the complete door past the face of the cage, it’s harder to seal but it doesn’t become trash like the factory doors would if hit a tree. Same with door handles.
Reactions: Mopower58 and BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
That's kind of what i was thinking to in set door under cage . Make top with like 2 5" pipes to drop in lower .Bolts to lock them in would good idea . Do you think I need the blue or make upper one piece. Any idea on handles to use ?
321,218
To make the blue part of the purple the hinges would either have to be offset or a scissor style to keep that area from binding and hitting dash. I did try a couple things and couldn’t get away without having it be in harms way. But a small triangle will work. Maybe you could figure something out. Older Wrangler door handles are recessed and should be cheap. Should be a nice look for sxs.
BWAF
BWAF
8,857
42,437
Carthage MO
That's what I figured on the binding I knew you would know . I was thinking about a wing style that would open and close like old trucks for the blue .
321,218
That would be cool
321,218
No pun intended!! Lol
Pun intended;)
Ya those handles. Simple steel rod to those latches you found and plastic clips. You know how they do it. You could do a light cover on the inside for a nice finish. Maybe with arm rests?
Better start an assembly line, everyone will be pm’ing you
Tigermark
Tigermark
Outside looking in.
Pun intended;)
Hey,
I want a set;) winter be here before you know it
BWAF
BWAF
8,857
42,437
Carthage MO
Arm rests hell yes ,I was thinking about jig as went so could make more, was thinking aluminum tubing , aluminum skin on out side guess I could put thin uhm on inside
