BOX1 - TEST
P700 Fun time tonight
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I am going to do everything tonight hopefully except no switches waiting for them and switch plate with 2 USB ports to show up . Switches coming from Amazon and plate from PBR.
20181228 163612
20181228 163452
20181228 163543
Tuco69
Tuco69
1,474
7,563
Middle Georgia
Post pics when done. Looks like the whole state will be wet for the next few days. I’ll probably be in the garage too.
Reactions: Backwoods
Diverguy
Diverguy
120
321
PA, USA
I just brought mine home from my cabin to add my winch, bumper light, reverse light, rock lights, and cab lighting. I also got the switch with 2 usb ports, as well as a volt meter built in. Also adding fender flares and floor mat.
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I got winch wired and mounted , wire and relay, fuse in for lights. I will mount them tonight when when we get back from visiting my daughter.
20181228 194905
20181228 174016
Backwoods
Backwoods
32,179
330,408
Douglasville ga
Hopefully my plate and switches will be here soon,but a couple more hours and every thing except that will be done. I put bumper back before I stopped
Reactions: swsebek and Koda
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I think I'll will wait till tomorrow. Just got home from Calera A la. It's supposed to rain anyway which seems to be an every weekend thing lately .
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I gave light bar wiring a test run before mounting and the switch stayed lit up with key out of switch. I don't want it to kill my battery can I fix by removing a jumper on rocker switch? Here's a picture of switch. I have held off running to ace hardware to get rest of mounting stuff because if the switch kills my battery it won't be of any use.
20181230 122823
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I googgled 5 pin rockers it looks like they put a jumper between fused power and rocker switch lights I think if I cut jumper and used a switched wire like white on acc plug that would only let switch light up when key was on. Does that sound right?.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
You are correct. I have the switch light run to the acc. plug and it turns on with the key.
Backwoods
Backwoods
32,179
330,408
Douglasville ga
Thank you i mounted light bar i will aim it tonight. I came with a rocker switch but a have a sasquach one on the way . And still waiting on switch plate to show up.
1rooster
1rooster
197
203
Fitzgerald Georgia
Where did you mount the light bar ? I have been thinking about getting one if I can find a good deal
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I mounted it on top of bumper , it is a flood spot combo. I will see how it does tonight and get it aimed, I will paint brackets with acrylic paint after I get it pointing like I want it. I rigged up switch so I can try it . My plate should be here any time it's been 3 days since I ordered it. Don't laugh at switch to bad it's temporary.
20181230 165754
20181230 165502
Backwoods
Backwoods
32,179
330,408
Douglasville ga
The switch for my rear light showed up but I won't do any thing else till my plate shows up. I stole the rear light switch from jackels thread I thought it was cool.
20181231 113556
Reactions: Mudwing and Todd627
Backwoods
Backwoods
32,179
330,408
Douglasville ga
I am going to work on it some more l got busy, lazy, put it off. I got to get my winch working shouldn't take long think it's how I hooked my rocker switch up.
Backwoods
Backwoods
32,179
330,408
Douglasville ga
Winch works fine new rocker switch is bad. Back to Amazon.
BOX2
box3 - TEST
