Gas Fumes?
41,769
Every once in a while i get a whiff of gas fumes. Doesn't appear to be any leaks.
Anyone else get this?
bigc
bigc
421
only when i eat alot of pinto beans :D
bigc
bigc
421
sorry i had to say that honestly i havent had any fumes from mine yet maybe others will post if they did have you checked under the seat area ? does it run correctly when you smell the fumes
41,769
Curiosity got to me so i went out and looked in the dark 20 degree snowy night with a flashlight. Looks like there is a vent hose that ends right behind the passengers knees. Probably just vented out a bit. Runs perfectly.
Reactions: moparornocar
rparris
5
0
I've noticed it on mine a few times.
If I am pulling trees and idling a lot then occasionally when I slosh the gas I'll get a smell. I think it is most likely the vent you found. I hadn't gone looking or worried about it.
F
farmer700
80
0
So, are yall saying this is normal?
If you constantly smell it, NOT NORMAL take it to the dealer before you ride it again.
If it is a brief whiff at rare random times yeah normal, that's what a vents purpose is.
slowdryrider
slowdryrider
563
756
Canada
I looked at mine today as well and have come to the conclusion that I'll need to put a in line fuel filter onto the end of the hose to keep dust out of the tank. I've done this to all my machines ,have even put them on the vent lines from the front and rear diff's.
Migglemuss
5
Montana
I have the same problem but mostly when I hit bumps or chuck holes. Did you notice that issue with yours?
Reactions: DG Rider
41,769
Dang...a thread back from the dead!!
Honestly, I was mostly hitting bumps and chug holes, so it would be difficult to tell. This only happened occasion until I put on a half windshield, and then it became very noticeable. It didn't stop until I extended the gas tank vent to the front of the machine...out in clean air. No more issues. Where Honda put this...to be honest, was kinda dumb for a machine with the potential to have a full enclosed cab.
Reactions: swsebek
