Gear oil brand
Houston313
Houston313
12
20
4FC02897 A6F5 4081 A046 F57C6A0E7F8B
Time to do the first maintenance oil change and from what I read a lot of you guys change the gear oil along with the motor oil to keep a track record. I’m new to the SxS game so I don’t really know what brand to use, was wondering if this brand is decent?
Reactions: sharp
67,230
Sorry for the late reply.
Never used that brand so I can't comment.
80w-90 is what it calls for. Go heavier if you want to quiten it down a little bit.
But that didn't help my 2016 1000 tho. Still has loud gear wine.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
I use the wal mart brand synthetic 75-140 and mix it half with lucas oil stabilizer .
Reactions: Remington and sharp
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
I just put the Honda oil in it I have over 3000 Miles with no problem. For the drive shaft Honda oil comes in a small 8-ounce bottle very convenient for filling up your drive shaft. But I guess you could put anything you want in it other people do. I try not to make life complicated too many other things in life to deal with.
jwfirebird
jwfirebird
927
1,446
western ny
good idea to change it often I do my oil and diffs on my quads once or twice a year because water and mud over middle of the tire you always end up with some in there. seals are not perfect. I get the syn from Walmart or Valvoline. most of the store brands are made the same by the same place anyway and they have decent price. napa synthetic oils are pretty good and if you catch a sale decent price.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
There are many options out there but would go with a major name brand. Regardless of major brand, you need hypoid gear oil. Hypoid gear oil is designed to meet the extreme pressure additives to prevent wear between the sliding surfaces of a hypoid gear system.
Reactions: Max718
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Mobil One Synthetic here.
Houston313
Houston313
12
20
Thanks guys, good to know you can come on here and ask for help cause I really don’t want to pay the dealer for something I can do myself lol
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
If your going to be running in a lot of mud and water I would recommend more frequent changes over a more expensive oil if budget is a concern. I've drained water out several times with no seal leaks and vented to my shoulder. Pretty metallic every time also as it seems most peoples are every time.
