P1000 Gear Shifter Problem
Youngster
Youngster
Manitoba, Canada
2017 Pioneer Deluxe 1000-5.
Recently when in park the P disappeared and I have a dash? When I wiggle the gear shift it will show a P for Park. When I let go it goes back to the dash? Is this a code? or are my cables out of adjustment.
When I start the machine cold it seems to run rough. Once I wiggle the shifter to display the P it runs normal-smoother?
Any help appreciated.
Reactions: TxDoc
5,022
22,428
Check out post #27 in the link. Make sure it's fully warmed up first. The Pioneer and Talon use the same procedure. I don't know how to tell if the shift cable is properly adjusted on the Pioneer.
Youngster
Youngster
Manitoba, Canada
I have done the reinitialization. It made no difference afterwards but thanks for advice CID.
Reactions: CID
