P500 Getting pins out
rustyneversleeps
rustyneversleeps
384
1,847
Montana
I feel your pain. I stripped/rounded one or two myself. Before rounding them completely, a friend had an impact driver that loosened them. Impact driver is the answer. I replaced those, plus bought two extra. They are expensive little screws. Must be gold filled.
Where did you get replacement screws? I've ordered more of both styles of pushpins, but need to grab a few more screws also. Thanks again
Isaiah
Isaiah
2,191
6,964
Altamont TN
Here's some more comic relief...any ideas I'm all ears. Got everything off and basically have the seatbelt clip exposed but cant get behind it. Last screw on the drivers side View attachment 272711to get the panel off and it is on there so tight I stripped it. Went slow with hand screwdriver, then slow with drill, then tried flathead. I can't get the thing off and it's stripped now like a mofo. So funny I need to add all this to my build thread.
I don't have any rubberbands at the house to try and not sure what else to do besides drilling it out or getting an extractor.
Any ideas?🤣
I would just cut the plastic off around the bolt and not worry about the bolt.
rustyneversleeps
rustyneversleeps
384
1,847
Montana
The question is what tip were you using? Those are #3 phillips not #2's. Just thought I'd mention that so you don't strip any of the other 3.
Thanks - I got 5 of them off without any issue and this one was the last one that was stuck. I'll have to double check the head size but I didn't have any play in the bit when it was in the screw head.
My OCD would not allow it 🤣
The Green Goat
The Green Goat
2,436
17,946
That's right, there are 6. They're for sure #3's though. Been several threads in the past of guys having a hard time with these. Honda torqued the hell out of them. Good luck man.
IIRC, mine looked a little corroded as well, even on a brand new machine. I'll be putting some anti seize on them when they go back in.
rustyneversleeps
rustyneversleeps
384
1,847
Montana
DvEOnVOUUAIl1Cj
Thanks guys! Took about 1 minute once I used the easy out like @SILVER_ALERT suggested! Now fingers crossed the seatbelt bypass works 🤣
PXL 20210520 194925091
PXL 20210520 194956220
rustyneversleeps
rustyneversleeps
384
1,847
Montana
PXL 20210520 201345121
Does this look right? I Thought the looped end was supposed to connect to the seatbelt?
Edit - I turned the key on with the connectors like that and the seatbelt sign on the dash wasn't flashing. when I connected the seat belt back together like it was originally, the seatbelt sign on the dash was flashing. wondering if that means it's working haha?
Mudwing
Mudwing
36,959
306,672
The Mud holes
You good. Congrats! 😎🤘🏾
GrnP500
GrnP500
90
217
COTXARLA
Get screws from Honda dealer. Where I got mine they had to order them.
Tom_C
Tom_C
158
473
Virginia, USA
It's probably been covered, but bikebandit or partzilla (or many others) have all the screws, etc. I had to replace several of those under the seats, on the dash, etc. And, you can get a bag of 100 push pins on Amazon cheap. Get extras, you'll need them.
