P500 Giving her a little more umfff
Peter_72
Peter_72
792
6,526
Louisiana
About too install a 35% gear reduction, no more struggling to turn those heavy 28’s.....my axles are going to hate me!
7A3DF553 18BD 4D55 AB82 E47AD28FE572
ADB85B32 B437 4001 AF54 DDDF01E5586B
Peter_72
Peter_72
792
6,526
Louisiana
Everything is installed and working, the torque is crazy! Getting the speed healer set up took several tries, following the directions got me close but I had to go the trial and error route to get it to run without it throwing a fault and stop shifting.
First thing was to see what the top speed is....I ran it up to 32 mph but it was screaming, 28 is about as much as I want to hear it going. Once when it through a fault I came to a complete stop and took off again pretty easy with it still in 5th gear
906UP
906UP
13,099
122,276
da Yoop
I went through the same trial & error with the Speedo DRD when I did the gear mod on the Donkey
Peter_72
Peter_72
792
6,526
Louisiana
Did you use the one from 12 o’clock labs or from somewhere else?
Reactions: 906UP
906UP
906UP
13,099
122,276
da Yoop
Same one, although that was a couple years ago, I think the design has changed slightly since then
Reactions: Peter_72
