Groundhog Max Disc Plow
BDI01
BDI01
19
37
Has anyone used the groundhog max disc plow with the P5? I am thinking about buying one. The plow gets really good reviews, but I think I will have to get an adapter to fit the p5 hitch. The plow comes with hook ups for 1.5" and 2" receievers, but not 1.25". The manufacturer keeps referencing a "heavy duty" receiver. I hope the My P5' is up to the task. Any input is appreciated.
Thanks
BDI01
scott
scott
1,212
1,354
lyman, South Carolina
I seen it break a lot of SxS and atv hitches. It happened on one pioneer 700. Broke the hitch off its frame. I would only use one if the ground was super soft and already plowed once by a tractor.
Code54
Code54
583
626
Hurricane West Virginia
I can see where that could be VERY hard on the hitch with the way it is designed. A normal plow is pulled so the force is outward not upward. When that hits something (like a large rock, root, etc) I would think it would put a LOT of twisting force on the hitch - if you had any speed it could break or bend something easily. With tractors when you catch a root/rock it is amazing how quickly a 6000lb+ machine will come to a dead stop. I personally would look for a tow behind style.
scott
scott
1,212
1,354
There is a lot of kinds out there i have used a small 4' pull behind harrow. Modify the hitch to use a 2' ball. Pulled it with my jeep. I think a pioneer could do it too. This one was really heavy tho. Good luck hope you find something let us know what you do.
BDI01
BDI01
19
37
Thanks for all the advice, I will probably end up with a pull behind type.
pilsbury38
pilsbury38
47
I just got a ground hog max , without reading any of this I went out backed up on the ramps and put it in the receiver.........sure enough 3rd lap broke my receiver to. So I went and welded it then went back out.......after being a little more cautious of what I was doing I realized even on the highest setting the disc was to far in the ground . I then went and got a receiver adapter to raise it up a couple inches and I couldn't be happier. I think the biggest problem is the Pioneer hitches are to low to the ground which puts way to much pressure on the hitch. Just my 2 cents......
Sent from my HTC6500LVW using Tapatalk
ehart814
ehart814
1,654
3,644
NWPA
I used this disc. Had cement blocks on top for extra weight, and a railroad tie chained to the back. Ran it for hours like this, no problems. It hooks up with a 2" ball. It pulled hard too. Had to run 4wd the whole time pulling, and occasionally would spin out all 4 tires.
Disc
Reactions: lee
34,176
I used this disc. Had cement blocks on top for extra weight, and a railroad tie chained to the back. Ran it for hours like this, no problems. It hooks up with a 2" ball. It pulled hard too. Had to run 4wd the whole time pulling, and occasionally would spin out all 4 tires.View attachment 15734
Yeah, but that was before you had good shoes!!!
Reactions: ehart814
162,994
I have a drag harrow from Tractor Supply. Only 4' wide but can be flipped around to dig deep, shallow or just grade. Cinder blocks will make it dig. P5 handles it easy just have to make more passes.
Reactions: ehart814
