P500 Header wrap to reduce underseat heat?
Treesniper
11
47
Anybody ever wrap the exhaust on a P5 to reduce underseat heat? If so what were the results?
20210424 121853
Reactions: J80 and Jerryg
158,116
Under seat heat was solved yrs ago, helps with noise and dust too. :cool:
HUCK
HUCK
1,047
2,315
ARIZONA
Wrapping the pipe is not a good idea . Could cause it to overheat and split . Use heat/sound deaden er . Contact Trigger
Treesniper
11
47
The material in the picture is exhaust heat wrap with stainless Zip ties made for high temperature pipes.
Reactions: happyfred
happyfred
happyfred
57
270
NY
Getting rid of the CAT would be the best option.
158,116
He's not talking about your wrap splitting, he's referring to the pipe itself. The wrapping won't allow the heat to dissipate the way it's intended and causes the pipe to overheat. Read where someone tried it on a 700 and that was the result.
Reactions: Mudwing and Mudder
happyfred
happyfred
57
270
NY
If the CAT is removed will it affect performance/running of the p5? Asking for a friend
No. Save weight and reduce heat. It's part of the exhaust pipe. Removal would require cutting and welding.
I've looked at modifying my exhaust .There is a lot of bends.
Decided too much work.
A new exhaust pipe is $400 plus. It'd be easiest to buy a new pipe, modify it and install.
The Green Goat
The Green Goat
1,776
12,641
I'm guessing the lack of a cat will cause the o2 sensor to spaz out? Any workaround for this?
happyfred
happyfred
57
270
NY
Nope. The O2 sensor is before the CAT and and monitors unburned oxygen. It then sends this signal to the ECU of which adjusts fuel ratio.
The CAT converts exhaust gases in to EPA approved gases.
158,116
It's been done before.
Bomersteve35
98
307
Portland or
  2. Other Brand
Man header wrap sucks. That's the best way to rot out an exhaust pipe as it traps dirt and water. If you want a pipe to be cooler go have it ceramic dipped. Will cut the heat down by half or more.
Reactions: Mudder
happyfred
happyfred
57
270
NY
Too much work but it sounds a lot better!
I may give it a go some winter. I'll buy a new Honda pipe and modify it.I have MC mufflers laying around and have used PC Vs and AutoTunes on my bikes quite successfully. 20% plus improvement on one..Excellent products....just need the motivation..
