P700 Headlight Relay
Bluejay700-4
Coeur d'Alene, ID
Can anyone supply me with a photo or schematic that identifies which relay is the headlight relay? Thanks
63,624
Look for the relay with the blue wires going to it. THATS NOT IT!
But it's the one beside it. Fdb5f313d1676f10e793ded51c2c8406
Bluejay700-4
Coeur d'Alene, ID
What are you after anyways?
Thanks.
I had installed a winch. Tapped into a red wire off ignition that comes on with ignition for winch switch & remote per instructions. Worked great but later noticed my lights not working. Disconnected winch wires & lights still don't work. Not sure if related. Checked wiring for breaks, fuses, etc but can't find anything wrong. I have the schematic so thought I should check relay.
Thanks for help.
63,624
Ok. If you remove it. Dont retap that spot. Thsts not a good spot. As you can see. It could leave you stranded.
Tap the white wire on the ACC Cigarette socket to use for your winch red wire connection.
Bluejay700-4
Coeur d'Alene, ID
Well....found problem. Up in the dark where my bi-focals don't like to work, I found where I had accidentally clipped a wire when I opened the sheath around it. Stupid mistake. Rewired winch switches to accessory supply wire & everything works great. Thanks for taking time to help out.
JimmyA
JimmyA
1,644
5,504
Northeast texas
Welcome aboard from Northeast Texas! Coeur d'Alene is a Beautiful place to live by the way.
