P1000 Heat reduction bilge fans
aauman88
aauman88
1,091
2,846
Here’s my idea for fans to help reduce heat under the seats. Let me know if you guys think it will work or if I need to try again. Still trying to decide on holes or vent in front to allow air in but it can be done after I finalize the fan setup. Will definitely get wired through switch and possibly thermostat as well. And this is just rough idea, I will change hardware out and tighten everything up once settled
B2BAE838 D243 42F5 9EDA E03C46C5ED48 1F6A7DB5 D04A 4CE4 AED4 4B4CF37B20F9 5425E809 86DA 4EFC 8A83 9C52FC49C2ED 650EC146 4503 45FA 8101 94C909FA73BD 87C02CF0 A567 425A 89F5 76873F8DCBDF BC1E1889 ED08 45E5 A0A5 E4D738432CE7
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
View attachment 112398 View attachment 112399 View attachment 112400 View attachment 112401 View attachment 112402 View attachment 112403
That will do it I reverse mine in the winter for heat in the cabC6dce1de36ea125d6a8ad05decd81b54
Tramguage1
Tramguage1
Texan
7,500
30,744
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
That will do it I reverse mine in the winter for heat in the cabView attachment 112404
I would like to something like this. Can that vent be closed? In Texas its gets pretty hot in summer. I dont want to let any more heat in the cab.
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
@Tramguage1 you might want to look at the 8"or 9" electric fans CP and others have used. I went with the bilge so I could turn it around, but it is loud. The are several threads on the fans and they are quieter and move more CFM than 2 4" bilge.
All of the fans under the seat will make a big difference. I didn't install any insulation once the bilge fan was in. I'm old enough a little lower back great feels good.
Reactions: CumminsPusher
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yep that will work, lots of guys have done it. On my first machine I had the exact same fan. Bought a new machine last fall and I'm going to use 2 fans this time.
I recommend venting them to the cab so it pulls cooler air to blow back. I reversed the wires when I wanted to blow warm air in. This time I'll just get smart and use a 2 way switch.
Reactions: Firemedic530
BWAF
BWAF
8,864
42,478
Carthage MO
Originally yes but took it off cause in summer have fan sucking thru it to keep under seat cool
Reactions: BigOL3
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Attwood 6031497 Attwood Flush louvered Vent https://www.amazon.com/dp/B0009TPXCW/?tag=sxsweb24-20
Thought about this in black on top where seat overhangs so really couldn’t see it. Will have to measure when home to see if it will fit
Being in Georgia does that mean you Don't really need the option to blow warm air into the cab? If so that vent should work to pull air through the cab in the summer
Reactions: BWAF
aauman88
aauman88
1,091
2,846
Yes I have no need to reverse fans to blow heat in. At worst just leave fans off if I need some heat. The pitch on fan doesn’t really blow much air when reversed anyway
Reactions: BWAF and Cuoutdoors
aauman88
aauman88
1,091
2,846
I have one exactly like that and it does a good job of putting heat inside the cab on those cold days.
Sorry I just mean in comparison to running correct way. Whatever works is great, I just have no need for more heat
Reactions: BWAF and BigOL3
aauman88
aauman88
1,091
2,846
Fan mount is done. Now to wire them. Is there any spare wires under the seat area? This is the only thing I will add this way so hopefully there’s a spare wire around here I can pick up on for these fans. Have 60mil rubber ordered to go under seat and up back like the ones Trigger makes for the 700
484DA316 84C4 4015 86F7 D7EB9C901E2B DD36DDA1 1819 4192 85C0 C5E518177C1A
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
View attachment 113079 View attachment 113080
I like it. Nice and simple. Looks good. What did you end up doing for a vent?
Reactions: Tigermark
aauman88
aauman88
1,091
2,846
Have long skinny one ordered to put on top where plastic sticks out under the seat 2”x19” I believe
Skjerv40
103
169
Minnesota
I know this is an older thread, but I bought a similar fan with the plans of pointing it down word to be able to blow heat and dust towards the ground from the engine compartment. Has anyone done this and had any luck? I’m wondering where to place it and also if there’s any concern that this method may keep the hot air from rising and keeping it in the engine compartment.
Reactions: BWAF
