Just finished my inferno heater install and thought I would share my install.I have installed 3 Honda heaters in the past and it can be a big job. My personal opinion of the Honda heater is that it sucks.The inferno is very similar except I didn’t remove the dash to install defrost vents ,one on each side of the steering wheel.what I did was come up through the cup holders.I used some abs plastic fittings from my local hardware store.It was very easy to route the duct hoses up from under the floor by reaching up under the front suspension and reaching in behind the dash from both sides after you remove your wheel well panels.The lower dash vents ,I installed left and right of the cigarette lighter which was easy. I will be installing a dual cup holder in the middle of my dash later.if I had it to do again I would install a heater inside the machine with no duck hoses.My heater works so so when your idling but as soon as you start driving the heater isn’t long cooling off do to the duct hoses being exposed under the floor and behind the dash to the elements.I find once you get some heat in the machine,all you need is 2 small fans,one on each side of the windshield for defrosting.
