Help 2018 pioneer 1000-5
Contoocook
16
25
Nh
please check out the video, it's 6 minutes and explains all the issue information on my machine and what I've already tried. Thanks
Reactions: Backwoods and TxDoc
64,288
With it rushing like that. It leads me to think it still could be a IACV issue.
Both the IACV and the injector wires are both known to have wire breaks right at the connector head. These would be intermediate and could change as the engine vibrates and moves around.
I would give the IACV and both injector wires a slight wiggle and pull to see if the rushing pattern changes.
Good luck.
I will see if I can find the code you mentioned.
Reactions: ChadD
64,288
Code 102 is: Abnormal Throttle valve position with the throttle pedal release - sticking throttle valve. Says engine speed may be limited.
1625367001994
Reactions: TripleB and ChadD
Contoocook
16
25
Nh
Good luck.
Ya I was leaning that way too, I wiggle the wires and there is no change , I have new injectors coming , I'll get a new iacv for 60$ and I'll get new injectors pigtails too
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Yeah I just had replaced my injector wire ends that I got from hondaSXS . Honda should upgrade the whole harness shouldn't be made that way. Should be a recall like every thing the cost and time is on the consumer.
Contoocook
16
25
Nh
What was your rig doing that made you replace them ??
Contoocook
16
25
Nh
Ya I got it to stay running and drove it up and down the drive way and it seemed like the throttle was unresponsive or just wouldn't work right. Isn't that a recall too?
64,288
There is a recall for the gas peddle.. But it's more for sticking. Like sticking from rust at the pivot point. Not electrical or sensor related.
If you haven't had this done, it needs to be.
Other possible recalls
Steering arm check.
Muffler shield.
Fuel pump (few select vins) (but you done that already. lol)
Park collar check.
Contoocook
16
25
Nh
Thanks for the info, I have an appt later this month , they will address recalls. I still have it running but the roads are weird and it's very unresponsive like it takes too long to accelerate after I press the peddle
