Help locating a part
xltman
xltman
188
369
US
Looking for a part for a 2016 Pioneer 700-4. It's item #41315-HL3-A00. I've called dealers, called every parts house, honda has a big backorder of them with no production date. A good used one will do as well. Please let me know
Thanks!! 13a2c3f951bc168ce44f8fccb1db22b4
Sent from my SM-F711U using Tapatalk
xltman
xltman
188
369
US
I appreciate the comment, but am not new at this. I've called every one that says that they have one, they all come from one of 3 main distributors. None of those guys actually have the part on the shelf. The major distributors have anything.
xltman
xltman
188
369
US
My hope is that there's one floating around out there, or a used one. I've come across 2 entire rear diffs that have the part on it on ebay. The same part is used on Rubicon's, Foreman, and some other models. If someone has a junk rear diff with this part I'd be interested.
xltman
xltman
188
369
US
That's good! I've done a few copart rebuilds, can make some good money on the right unit. I bought a "non running" rzr once that was a full custom build. Found the hidden ignition switch, replaced all of the relays (water damage) and it fired right up!
115,738
US is short for unstable.
You or our country?
And you have to hit the relpy tab if u want someone to know your replying to them or they might not ever see it unless they check the thread. Just some friendly forum etiquette help. 😘 NoMo.
Reactions: Smitty335 and CID
115,738
That's good! I've done a few copart rebuilds, can make some good money on the right unit. I bought a "non running"POO POO FIRE TRAP rzr once that was a full custom build. Found the hidden ignition switch, replaced all of the relays (water damage) and it fired right up!
Fixed it for ya! 😉
xltman
xltman
188
369
US
You or our country?
And you have to hit the relpy tab if u want someone to know your replying to them or they might not ever see it unless they check the thread. Just some friendly forum etiquette help. NoMo.
Yes aware of reply. Unstable can go for both.
115,738
Yes, Brandon has it very unstable Fo Sho!
So where are you actually located?
208,726
We ride everywhere, been on here quite a while as well. Just come out of the woodwork every once in a while.
Now, lets find a part that Honda is out if stock on!View attachment 377733
Can you have a machine shop get you outa a jam?
115,738
Now that all the important things out of the way, im sure All resources here will be available to help u do that.
If try calling dealers up the ying yang in state and out of state and see if they have one? There has be one someplace. Exhaust all options.
