P500 Help me make my tire and size choice?
I'm getting ready to get some tires also, either bighorns or bearclaws. But will a taller tire make the machine more tippy than it already is or will the extra width offset that?
With 26x9 and 26x11 I see no more tippiness at 8-10 psi than I did with the OEM. But I wouldn't say no tippiness as these P-5's are so by nature. I'd never use the rutted out gnarly trails that I do right now with 28's or 30's as I see some guys running. Then you need the 1.5 wheel extensions which then requires the fender flair extensions and eventually you should have just bought a 700 if that's what you really wanted.
scott
scott
1,212
1,354
lyman, South Carolina
I bought the bear claw HTR's. Got the fronts in today, and put on. I really like that they have a square footprint and true to size. They really are 27" tall and 9" wide. Rear's will be here tomorrow.
Hardwaterflyer
65
102
West Central Minnesota
I have the Bearclaw HTR's on my P2-700 and they are 8 ply. Great all around tire. Big Horn originals are 6 ply. Had those on my Ranger 500 (sold it) and they were every bit as good. Maybe better in snow. HTR's win out just barely because of the 8 ply. I will be putting my "takeoffs" from the P2 on the P500 to start with. Still waiting for the camo P500 to arrive.
scottp500
scottp500
46
65
I just want to make sure I'm not going to fall over every time I'm in an off camber situation, which is a lot here in Indiana:) Anyway I want a taller tire and I'm going with new wheels, 5X2 offset. I have put 1 inch spacers on the rear but not on the front. I should still be around 53 inches or so and thats OK for me. The 700 is 60 inches.
As you surely have already noticed, the P-5 is tippy by nature. Any attempts to make it higher without making it wider will increase that tippiness. At some point, one might as well buy a 700. I run my tires with lower psi to compensate, that's with 26's. I now know that I'd never run 28's or 30's as I see some do. I routinely get one or two wheels off the ground with the P-5, I've owned a PoPo for six years and that has never happened.
Reactions: rocmar and scott
rocmar
rocmar
4,741
5,778
4 CORNERS
Also lower your pressure to 6 , this will help more then anything else to prevent puncture.
with psi at 6.......you don't get
the true height of tire...
Reactions: Montecresto
Talen
Talen
159
188
Central PA
26" tusk trilobites. Knock off of big horn. They are 9 wide in front. 10 in back. I did add hub extenders. But best thing I did, was remove sway bar. Much more stable. Much. Not constantly on 3 wheels
Nope, you sure don't. I don't get it at 8 psi.
How's it behave at speeds on gravel roads in turns?
hambone
hambone
154
89
Southeast Indiana
There are hills in Indiana? :)
solrus
solrus
1,629
2,511
Montana
I dont care about height, for me comfort and less flat tires matter more. Too rocky where I ride.
scott
scott
1,212
1,354
Try the bear claw HTR. 8 ply. I've got them and so far i really like them. Only had them a week, so i can't say too much. The black daimond XTR has great reviews in rocky terrain btw.
scott
scott
1,212
1,354
My 27" bear claws are dead on in their size height and width, and i love that. That was the reason i didn't buy the black diamond XTR they run small.
lwhite571
lwhite571
431
3,575
Central, IN
I put 26 x 9-12 on front and 26 x 11-12 on back Maxxis Ceros also on today,WoW what a difView attachment 12795 View attachment 12793
20160331 192508 HDR
20160331 180947
20151011 174715 HDR
View attachment 12793 View attachment 12794
