P500 Help me make my tire and size choice?
Frisco
Frisco
89
138
San Francisco, CA
  1. I have to keep within the 50" (for the truck bed and my storage shed) Literally no room for more width in the shed.
  2. Do not care about losing some speed,or stiffness of ride.
  3. Want a tough walled tire (want to prevent a flat as much as possible) lots of sharp rocks out here in Norcal
  4. Do ride in some mud (the stock tires have been actually good enough so far). But don't need swampers.
  5. Want to keep stock rims ( I actually like the look of them).
  6. Want bigger tires (not to big- do not want to cut anything). 26" , 28"? something aggressive enough to climb really well.
  7. Don't ride everyday, (maybe twice a month)so wear should not be too much of a issue.
So what style BearClaw, Ripsaw, Bighorn? size for front? size for rear? Which style and size would get close enough to match what I want? thanks everyone!
solrus
solrus
1,629
2,511
Montana
Go either with Original Bighorn or STI Roctane XD 26" and 9" wide all way around on stock rims
or
Tusk TriloBite HD , a bit budget choice, but has same pattern as BH.
Reactions: KJatNL
I
Ichybod
159
231
Tucson, Arizona
I've got Artrax CTX radials, 26x9x12 & 26x11x12. Basically, Bighorns knock-offs. I've been very pleased with them so far. Price for all four tires was under $300!
sthomp54
sthomp54
375
I like the 26 bearclaw htrs. I'll just warn you that you will get tons of opinions on tires, kinda like the oil threads. you will need 9-10" tires to stay less than 50" I have 11" bearclaws on rear and it is 50.5" 9" would be less than 50"
scott
scott
1,212
1,354
lyman, South Carolina
bear claw htr, black diamond xtr, black water evo, pitt bull rocker, big horns, 26" any of them will make you happy.
solrus
solrus
1,629
2,511
Montana
Thank you for sharing this, I had them in my mind but could bot remember the brand name. I will try them next time I need tires.
I will be curious how many miles you will get on them.
solrus
solrus
1,629
2,511
Montana
  1. Want a tough walled tire (want to prevent a flat as much as possible) lots of sharp rocks out here in Norcal
Also lower your pressure to 6 , this will help more then anything else to prevent puncture.
Frisco
Frisco
89
138
San Francisco, CA
Great tips and info. thanks. I will keep watching for more comments. Think I will go 26" (height) 9" (width) all around. looks like a decision between bearclaws or the bighorn knock offs.
Reactions: Ollie
solrus
solrus
1,629
2,511
Montana
BH knock offs, they have more universal lug pattern, and even distribution that will give better grip on rocks and quieter ride , to my opinion BC are like tractor mud tires.
Offtopic, every time I look at your avatar with location , I wanna sign: If you're going to San Francisco, Be sure to wear some flowers in your hair. Good song :)
Frisco
Frisco
89
138
San Francisco, CA
Ha ha! Your killing me. But I love it. .....I knew the SF would raise some eyebrows. Although I don't wear flowers or own any bell bottoms. But I would cruise the 500 down Market st. Listining to Darling Dunkechane!
Frisco
Frisco
89
138
San Francisco, CA
I'll post a video if I can pull that one off. :D
Bighorns 26x9 front and 26x11 rears is a good package!
SBuckJ
SBuckJ
214
216
Central PA
Just from tires I know and have had...I had Swamplites and Reptiles (both Interco). great tires and soft but wear fast on hard pack and gravel roads. Mudlites..good tread but had trouble with sidewall slices. Maxxis Zillas, great mud tire but a little uncomfortable on hard pack due to lugs. Carlisle Black Rock, horrible all around.Best all around tire I have had(good on all terrain but not the greatest on any one) is the Kenda Bearclaw HTR's I have now...I had a set on my past RZR too. Love them. I have 27" now and the same on the RZR
He needs to stay 50" or <, then 8 and 10" as factory with 26" instead of 24"
Yes, I did too, which is why I stayed with the OEM wheels. I still fit in the bed of the truck, just fine.
You'll still fit in the bed of the truck with Bighorn 26x9/26x11.
scottp500
scottp500
46
65
I'm getting ready to get some tires also, either bighorns or bearclaws. But will a taller tire make the machine more tippy than it already is or will the extra width offset that?
I
Ichybod
159
231
Tucson, Arizona
I have 26X9X12/26X11X12s, and I see not tippiness at all.
