So, I have a Forest River motor home with a Ford E450 chassis. This has a side collision warning system that will light up when someone is beside of me and then beep if I put the signal on to turn if someone is setting off the sensor. Not sure if this is a Ford or motor home system, but whoever hooked it up wrong. The alarm beep occurs when you turn the blinker for the opposite side of where the sensor is lit up.
So, if someone is on my left the system will alarm when I put the signal on to go RIGHT. I bet I just need to switch a connection, but no idea where the connections would be.
Any ideas?
Any ideas?
