Help with side collision warning system
sugarray
sugarray
Is this a game show?
661
1,257
WV
So, I have a Forest River motor home with a Ford E450 chassis. This has a side collision warning system that will light up when someone is beside of me and then beep if I put the signal on to turn if someone is setting off the sensor. Not sure if this is a Ford or motor home system, but whoever hooked it up wrong. The alarm beep occurs when you turn the blinker for the opposite side of where the sensor is lit up.
So, if someone is on my left the system will alarm when I put the signal on to go RIGHT. I bet I just need to switch a connection, but no idea where the connections would be.
Any ideas?
208,011
Any ideas?
Dealer?
sugarray
sugarray
661
1,257
WV
I'm 3 hrs from the FR dealer. Local ford dealers won't service due to being a MH. Ridiculousness from the 3 local dealers I called/visited.
So, I'm on my own. Trying to get an idea where the control unit would be.
I did look after work and appears to be behind the dash. There is a 150 amp disconnect on the battery though, which is somewhat reassuring.
FR owner's site has so far been unhelpful
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
@Neohio Might be able to pull up the ford wiring diagram
Rockydog
73
165
Canada
Any ideas?
The dealer that sold the unit to you should be able to tell you.
sharp
sharp
3,757
14,955
Tennessee
If its the Ford BLIS system you should be able to adjust it somewhere on the dash. You can also adjust it for the length of a trailer you are pulling so the alarm works for the camper and trailer at the same time. just a guess, dont hold me to it. Lol
sugarray
sugarray
661
1,257
WV
The "dealer" has so far been unhelpful with any questions.
I'm beginning to think it isn't a Ford system, it looks completely aftermarket. There are no adjustments on the dash. I'll try to remember to get pics at lunch today when I go home.
Reactions: sharp
Rockydog
73
165
Canada
If the dealer doesn’t want to help try Ford Motor Company direct. I’d bet after telling the dealership they be falling all over you trying to help
Reactions: sharp
My dad had an issue similar to this and he couldn't get anyone to help FoMoCO said the wiring was modified by the RV manufacturer and the RV Manufacturer said it was Ford harness. He ended up cutting the wiring harness and fixing it himself. It took him several months to track the wiring down and figure out where he needed to cut and splice.
I think some RV manufacturers have much better relationships with Ford than others do. I know Ford wouldn't work on his transmission either because their bays could not fit/lift an RV. They supplied the parts under warranty but he had to have it worked on by someone else.
Were looking at a SuperC at the moment and it seems International has a MUCH better working relationship with the RV manufacturers than Ford/Chevy/Dodge do.
sugarray
sugarray
661
1,257
WV
I completely forgot to get pics.
Ford MC gave me 3 commercial service dealers, which are all minimum 2 hrs away, but at least say they will work on the unit. I'm getting an alignment done over the next few days so I'll spend some time on it next week. I'm working everyday until 11th so, won't have much time.
Mopower58
Mopower58
CST is the Best!
69,706
641,053
Crystal Springs,Ms.
I worked at a big Ford dealer for many years. Back then all the camper conversion people knew was that a red wire was hot. Everything had red wires.
Reactions: ohanacreek
Then I’d say you’re absolutely correct.. they swapped them they tapped the wires. It’s probably not far off the control module for the collision system. I’m assuming there is a box or something that the beep is coming from under the dash, or in the dash?
Most definitely in an easy access point unless it’s connected in underneath somewhere then you’d think just behind the cab or the rear bumper.
Reactions: JTW and sharp
