P1000 Help...
John_S
59
114
Tennessee
My searching is not going very well and I know this must have been discussed at some point. I'm considering a new set of rims and tires for my stock P1000 SE.
I want a better tire for trail rides in NW AR. Wooded trails, rocks and water crossings. I don't want to put my axles and gearboxes at risk (will change at a later date) and increased height is minimal. Please point me in the right direction.
PJon
PJon
780
3,158
Arizona
If you plan on rotating tires, go with 14” 5-2 wheels. For tires I’d go with 8 ply 10x28Rx14. Actual diameters vary, so try to pick one that is not over 28” and you won’t have to worry about rubbing. If you want the front and rear track to be the same, add 1” wheel spacers to the rear. RB3 Offroad makes a nice set that are a little wider than 1” and you won’t have to grind down the original wheel studs or the height of the lug nuts holding the spacers on to the hubs.
Lady01
Lady01
192
488
Midland Michigan
When you decide on changing your tires/wheels out consider KJMotorSports. they do tire/wheel combos and very competitive prices (already mounted).
