P1000 hi lifter
105,595
Hi-Lift makes a tube mount for bull bars and similar mounts. The jack makes a great bumper but sucks as a jack especially after it fills with trail dust. They make a neoprene cover but I've gone through two and at $70 each, they don't last long on the trails. Note; keep the zipper on the neoprene sprayed with lube like wd-40 or it won't open. I had it on the 500 before moving it over to the 1000.
2B9D13AE 48D3 4FFE ABD2 246EA207859A
9154282A 1CF8 4082 9A6D 4F8A8D812742
F80D2219 4803 4980 B530 271B8803340C
Ultrasonic1
Ultrasonic1
206
766
Nomadic
This may get you started in the right direction. I’ve seen this used on other sxs brands and Jeeps. A couple of U bolts, large washers and wing nuts could get you mounted for $10 - $15. Exhaust clamps from the auto parts store would work the same way and probably be stronger.
367C0378 E87E 4ACC B353 13FF86B76E55
20C78DBB 89AF 40A7 93F6 0E9A23F51A93
70E0373F 60BC 45F1 A3FB F2A3C6CF68BD
8FCE5DE4 825E 46DA 8A08 776BB602E1D9
28B1DF48 A0AF 40FD 98DB 45EF35079C3F
Reactions: TripleB
Ultrasonic1
Ultrasonic1
206
766
Nomadic
No problem, I hope you get what your looking for.
Reactions: Isaiah
