P1000 Highlifter 2.5 Lift question.
Brewtus
27
106
Brighton, Illinois
Bought and installed the highlifter 2.5 lift and my rear tires look to be angled in and riding/sitting on the outside of the tire when you look at it from the back. Anyone else's do this or is there something I need to adjust, take off? Thanks
Not the best picture, I'll try to get a better one this evening.
IMG 7999
You may take some of the preload out of your rear shocks by adjusting the large nut at the bottom of the shock. Other than that, there won't be any adjustment.
After you ride around and everything settles, it may look better. Also, after you add some weight in the bed it will level out more.
Reactions: trigger and pct
Brewtus
27
106
Brighton, Illinois
thanks. I'll try that. I haven't ridden it much lately. Have had it taken apart and adding accessories. Just noticed it sitting differently than it should. I'll try those suggestions. Thanks
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
The axles will have a nice angle to them with that lift. Roughly around 32 degrees. You may get some of it out as suggested but don't beat yourself up over it. Mines been at that angle over a year now and still factory axles.
Reactions: pct and joeymt33
Reno58
Reno58
74
Middle TN
I know this thread is a little old but have a question regarding the High Lifter lift and rear positive camber.
I have installed the 2.5” HL lift along with the front Super ATV forward a arms. I adjusted the front a arms to allow for a 2 degree negative camber and eliminating the “ballerina” look in the front. It also drives much better.
My question is can you install the rear SATV forward a arms - for adjusting rear camber - and not do any damage to the rear axles. On SATV site they say you must use Rhino axles in the rear with THEIR lift kit which is 3”. Is this the same for HL lift with the SATV rear a arms?
I like the HL lift giving me a little more center line clearance along with the “beefier” stance. The only dislike I have, other than putting the rear axles in a increased angle which I expected, is the rear positive camber I’d like to adjust.
Any advice/inform I can get is appreciated.
Rambo
Rambo
339
822
Southern Indiana
The lift you put on will be the only thing affecting your axle wear. Putting the arched A-arms on the rear won't make a difference from where you are now....
Plenty of people are running the high lifter lift and arched A-arms on stock axles.
Reactions: Plumber32 and JTW
I didn’t like the camber with the HL 2.5” lift either.. I ended up adding the SATV a arms and then went to 30’s... I’ve ran both SATV axles and stock axles.... they’ll both still break. But if you have good stock axles I wouldn’t change just for that.
Reno58
Reno58
74
Middle TN
@Rambo, @JTW thanks for reply and info.
I noticed that Highlifter rear arched a arms do not push the axles toward the rear like SATV rear arched a arms do (1.5”). HL states they have a washer with an offset slot, located where the hub bolts to the lower a arm, that can be flipped one direction for no lift and the other direction for a lift to allow camber adjustment. Has anyone installed HL’s 2.5” lift and rear arched a arms that can chime in?
I like the HL idea but prefer the adjustability of SATV’s rear a arms. Just that the Karma Sutra position of the rear axles being off set to the rear 1.5” makes me wonder. LOL
Just buy the SATV... there are lots of us running them... we know they work!
Reno58
Reno58
74
Middle TN
Pulled the trigger and got a set of SATV rear a arms. Will put them on this weekend.
Thanks for input.
Reactions: JTW
Reno58
Reno58
74
Middle TN
Installed SATV a arms Friday.
All went smooth but sway bar gums up adjusting camber. Makes for extra step in adjusting bottom arms for camber, not as easy as adjusting the front camber. Got it done though. LOL
@JTW to get 0 degree camber I had to run adjustment out quite far over the ‘pre adjusted’ stetting. I ended up with right at 7/8” gap between backside of pivot blocks and jamb nuts. Does that sound right to you? I’m sure tire type, diameter and pressure plays on the adjustment.
Haven’t put many miles on it yet but I like the ride and the ‘twitchness’ when cornering at speed is almost down to stock.
Axles don’t bind or make any noise but I will keep an eye on them. I ride mostly on county roads and almost never off road so I’m thinking this setup should work okay.
Yeah.. the “pre-adjustments” aren’t really set for the machine you have to go thru the process as the directions state. Unless you have the measurements of someone else with a like machine. Mine has a HL lift also, and Fox shocks which will change my camber vs yours. Unless you have those my thread measurement won’t be exactkybtge same as yours. But as I recall... that is close to what I have. I’d have to measure to say exactly.
