P1000m5 Highlighter 2.5” lift
RickMaynard
101
121
Arkansas
I have the opportunity to buy a new in box hL 2.5” lift for $100. I was curious from those of you that have it installed, do you regret it? Are there any negatives to installing it? I’m on the fence at this point. I just bought and installed new 28” reptiles and they fit fine. So should I or shan’t I?
CPope
CPope
352
1,152
Pulaski TN
Sent from my iPhone using Tapatalk[/Qif
It depends if you want a stiffer ride, the HL makes it a little stiffer than the factory ride. If you decide not to get it, let me know, my son in law is wanting one for his 1000.
Reactions: pct and BWAF
RickMaynard
101
121
Arkansas
Ok, thanks. Not really wanting a stiffer ride, just a little more clearance.
Reactions: BWAF
I like mine.. it is a little stiffer but it’s not bad, I really like the feel better. And it does add the clearance, which is handy! For $100 buy it and if you don’t like it someone here will take it off your hands. It’s an easy install and adds strength at the shock mounts.
RickMaynard
101
121
Arkansas
Ok, thanks.
Reactions: BWAF
Negative... you loose a little width and it does add to the cv angle.. but I don’t know of anyone that’s been an issue for.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Mine is about 2.5yrs old and still like it. Ran with stock shocks. The rear axle angle is on the steep side but hasn't caused me one problem yet. No regrets whatsoever.
Reactions: JTW and RickMaynard
RickMaynard
101
121
Arkansas
Thanks for all the input. I guess I’m gonna bite the bullet and slap down a Benjamin.
Reactions: pct
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I ran that lift for a few rides and removed it. didn't care for the higher center of gravity. everything is a tradeoff, so really just depends on how and where you ride.
nbomar
nbomar
4,416
17,854
Springdale, AR
Wish I could take mine off because of the higher CG. Hasn’t caused an issue yet but it’s definitely noticeable. Ask @Kilo427 or @Tramguage1 we all drove up hanging rock at mulberry fine last time and now those with lifts ride big wheelies up it.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Some rode bigger wheelies than others lol.
208,726
Aftermarket shocks will help with clearance , to a point, add Super ATV arched A arms and 30 inch tires, and now you are close to a 2.5 inch lift in clearance or more. Comparing to lift and stock shocks and A arms. And you don't change the angle of the dangle on your shocks.
Reactions: pct
Fireman013
Fireman013
35
30
Nashville Area
Doing a 30” tire on 15” wheels and used spacers to add stability to ride. Rear only
