Hight restrictions when jacking up
sspeederr
sspeederr
391
661
Just wanted to share idk if anyone has a bit if hight restrictions when jacking up there unit for service like I do. Everyone knows that these things have some serious suspension travel and if ur work area won't let u jack it up enough get tires off ground using a sinple ratchet strap to strap down the suspension prior to lifting will help you. I lace mine around the frame and to trailing arm (on rear) or lower control arm (on front) just enough to start to pull suspension down then I can jack it up with out suspension dropping to low. Hope this helps some of u all 20201102 15580420201102 15581120201102 16050420201102 160458
Fatsquatch
Fatsquatch
Approved Member
120,988
1,009,215
Hidden
Just wanted to share idk if anyone has a bit if hight restrictions when jacking up there unit for service like I do. Everyone knows that these things have some serious suspension travel and if ur work area won't let u jack it up enough get tires off ground using a sinple ratchet strap to strap down the suspension prior to lifting will help you. I lace mine around the frame and to trailing arm (on rear) or lower control arm (on front) just enough to start to pull suspension down then I can jack it up with out suspension dropping to low. Hope this helps some of u all View attachment 233152View attachment 233153View attachment 233154View attachment 233155
A good tip for newbies to long suspension travel.
