P500 Honda P500 Stuck in 2nd?
DRZRon1
DRZRon1
850
2,734
its not mine, dropped off while at work by my friend with a "will you look at" text ?
P500 -not sure of year, 3424 miles
it starts right up, display reads 2 in gear position indicator in manual and auto, machines drives forward , does not shift, paddles don't do up/down shift, reverse doesn't engage\work - used at a local quarry, won't ever know if swamped or history. I moved the lever to 4wd, the 4wd indicator came on. engine sounds good, no knocking.
the extent of troubleshooting so far was to use the seatbelt - no effect.
gear indicator displays 2, then 4 long blinks and 7 short blinks
found a 2015 manual on-line, could not figure out the code (its bs I don't know the year and asking for help)
here are pics - it did happen
it does have a custom roof mounted chase light....
any ideas on where to start? IMG 8634IMG 8635IMG 8633IMG 8636
906UP
906UP
13,039
121,577
da Yoop
With the auto/manual switch it's a '17 or newer model. The code you mentioned doesn't show up in the service manual, should be more numbers.
DRZRon1
DRZRon1
850
2,734
thanks all, its the 2 that flashes if that makes sense, it just goes around the loop 5-7, 0r 4-7, either 5 long or 4 long and 7 short flashes of the 2..........
if that makes ant sense
ughhhh.......
Mark in Northern Iowa
465
2,080
Floyd County, Iowa
kramnella.wixsite.com
"Starts right up"
Many stuck in gear 500 problems are weak battery.
Load test the battery to eliminate it as a possible problem.
Other common,
- The throttle cable is moved when changing oil, so the idle is to high.
- Mouse chewed wires
- Clutch out of adjustment
Have a good day
Code 57-1/or57-2 refers you to code 41-2 Gear Position Switch malfunction.
Can you manually shift the unit?
Reactions: Buggyman
DRZRon1
DRZRon1
850
2,734
hey hey thanks for the starting points, really appreciate the guidance,
this one is new to me, so doing a bunch of searching on inner web while watching this bust of a championship game
gotta go outta town for the next week for work, so ill go dark on this for a bit, ill get on it this weekend hopefully
learned where to manually shift it here in a few short hours, etc.....
shoulda checked the basics before posting but wanted to learn a little as well
DRZRon1
DRZRon1
850
2,734
checked battery voltage while running - 14.2v
Tried to manually shift with tool up and down - won’t budge…..
buddy pulled battery this week and had tested, tested good
hit the downshift paddle and the dash dims and you can hear it trying to shift
hit the up shift paddle and nothing tries
seems locked solid mechanically in 2nd gear
Any ideas?
Any ideas?
Try rocking it while shifting manually?
Reactions: Buggyman and 906UP
You might have something broken behind the front cover most likely.
I'd bet the return spring is broken or the shift plate.
