Honda pioneer 1000-5 and 1000-5D bolt on spare tire racks
Moses
Moses
Owner - Brick City Fab
202
490
Gilbert arizona
Honda 1000-5D and 1000-5 V2 rack $499 plus shipping
That includes:
•Cooler rack for a yeti tundra 45 Or something similar to those dimensions. The yeti tundra cooler is
13-3/8" deep and 24-1/2" wide
•Rotopax mounting bracket plate
Www.rotopax.com
• Spare tire mounting bracket with welded M12-1.5 lug bolts and lug nuts set up for a 28" spare. (Can be modified to fit your needs.)
• 4, CNC machined 2 bolt cage clamps with 4 cnc cut pivot rod brackets TIG welded. Machined in house here in Gilbert Arizona
• 2, 1/2" Stainless steel T handle pivot rods with 4 pressed urethane shoulder bushings
• Powder coated any color with a 60% semi gloss
•2 interlocking tube clamps to split the rack in the middle of the horizontal cross tubes
Payment options
Intuit quickbooks
I'll just need
First and last name
Billing address for the card you'll be using
Shipping address
Color of the rack
Thanks.
Shipping dimensions
16x24x34
52lbs
Ships from Gilbert Arizona 85233
Moses
Moses
202
490
Gilbert arizona
IMG 8087
IMG 8085
IMG 7989
IMG 7987
IMG 7988
Moses
Moses
202
490
Gilbert arizona
That's awesome what does the one for a 700-4 run and does the one for a 700 come with a gaurd for the cooler like 1000
I just offer the "cooler shelf" its limited on space compared to the 1000-5 here's some additional information on the 700-4 rack
Honda pioneer 700-4 spare tire rack with yeti cooler mount
Built to accommodate a yeti tundra 45 cooler or a cooler with similar dimensions and a 26" spare tire
Standard carriers include:
• Spare tire rack
• 4-110 Spare tire mounting bracket with welded M12-1.5 lug bolts and lug nuts
• 4 CNC machined 2 bolt cage clamps
• 2 1/2" Stainless steel T handle pivot rods with 4 pressed polyurethane pressed shoulder bushings
• Powder coated 60% semi gloss black (raw or other colors available upon request for an additional fee)
• Cooler rack shelf
•$550 shipped
Rotopax mounting bracket is an additional $50
Weight-32/38lbs
Please allow for up to a 2/2.5 week lead time to ship as we are on a build by order basis.
Shipping dimensions :
16x16x64 shipping from Gilbert Az 85233
Please pm me for more details or you can also email [email protected]
Also give us a follow on Instagram at brickcityfab_az
Thanks!
L
Logdog90
5
Havana il
• Spare tire rack
• Cooler rack shelf
•$550 shipped
Weight-32/38lbs
Thanks!
That's great looks like u do some great work only issue is I run 27inch tires and don't really need a cooler mount but thanks for the link I'll do some thinking and message u
Moses
Moses
202
490
Gilbert arizona
sounds good. I can also modify it to fit your size tire. Those are just specs based on all of the options added together. I have a standard rack that may better suit your needs. with that you would be able to run a 30" tire if you wanted to. This rack would be $500 shipped
IMG 8198
Reactions: ohanacreek and JTW
Moses
Moses
202
490
Gilbert arizona
That includes:
Www.rotopax.com
Payment options
Intuit quickbooks
I'll just need
First and last name
Shipping address
Color of the rack
Thanks.
Shipping dimensions
16x24x34
52lbs
211,897
Nice work! I'm not into adding weight on the butt end of mine, I try keep the weight as close to center as possible, but do you make a competition chop rops system that has no warranty as far as safety?
Kaptain
Kaptain
Marsing, Idaho
Just got my rear rack for my P1000-5 from Moses. Absolutely fantastic and great communication and service. Really a work of welding art. check it out [email protected]
7,600
31,472
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Yes I still have one that was originally for my 700. But Moses built me some coustom brackets so it would fit my P1k.
I'm interested in parting with it, DM me and we will discuss.
Reactions: ChadD
