Honda pioneer 1000-5 fluids?
Urdaddymike
Urdaddymike
Baytown
Anyone have the list of factory fluids. I'm trying to do a whole fluid change and want to get it right. It's the first time after the dealer ships first service. And it's brand new and don't want mix anything up.
Rayger143
Rayger143
2,758
23,900
Winfield, BC Canada
I recommend you get the service manual. Very handy. If you upgrade your membership you will have access to download it.
Screen Shot 2021 08 12 at 93712 PM
Hillbillytnt
Hillbillytnt
521
1,922
Ky
The engine oil sub trans and trans all use the same oil if that’s what your worried about.
Reactions: Rayger143
HBarlow
HBarlow
1,614
5,997
Daniels, WV
Plus Honda anti-freeze/coolant if you are really dedicated. Factory coolant has a service life of several years under normal conditions.
Urdaddymike
Urdaddymike
Baytown
Thanks I found the service manual. I'm a bit ocd or something I like to check every time before I do anything to it.
HBarlow
HBarlow
1,614
5,997
Daniels, WV
Always better to check before doing something rather than after you screw it up. I've tried it both ways.
P1K5Dave
P1K5Dave
2,182
8,170
Petoskey, MI
The confusing part is that the engine and the DCT share the same oil, all filled by a single "fill" port. However, there are two separate drains, but the drains aren't "Engine" and "DCT"... actually "oil pan" and "oil tank."
And then there are separate oil filters for the engine and DCT.
The sub-trans is a separate deal altogether, using the same grade of oil as the engine and DCT, but utilizing a completely different set of drain/fill plugs and no filter.
This all took me a while to sort out in my brain.
