Honda Pioneer 1000- 5 Recommendation Tires for Hard Surfaces
RobertCarstens
6
6
Dune Acres, IN
duneacres.org
I have a 2016 Honda Pioneer 1000-5 which I love - my usage now is about 70 percent on asphalt and 30 percent on sandy beaches near my house. Given the amount of asphalt time I get major tire wear. Does anyone have experience with using DOT harder compound tires that can still manage soft sand conditions - any recommendations or insights appreciated - at this rate I go through my tires - especially the front set about every two years.....thinking harder DOT compound options might be a good thing.....
Reactions: TxDoc
Vikes79
Vikes79
SKOL!
11,102
107,765
South Dakota
  2. Talon X4 LV
Has the front end been aligned? The pioneers are often toed out from the factory. Pretty common issue. Mine was .75” out. Should be 1/8” toe in. Front tires will last much longer!
simple search for alignment on this site will yield many how tos.
Congrats on the first post!
Reactions: TxDoc
bigshoe
bigshoe
421
1,426
General grabber atx comes in a 28 14. if your running that much pavement thats what i would put on it . Everyone has different opinion on the alignment do some research. at very most zero it out, I run 1/8 toe out seems more stable at higher speed on pavement.
