P1000 Honda Roof + SuperATV Flip Up Windshield Clamp Question
tigerj
tigerj
Louisiana
The only thing incorrect on your setup is the 2 front outer clamps. The rest are correct.
ok so this is the final verdict?
just the outside front clamps are wrong?
i will remove and reinstall then work with windshield if all agree
Russ989
Russ989
22,642
147,257
Your 2 center brackets are on backwards, his are correct.
Mine were all on the roof already when I picked it up from the dealer, I had to turn the rear brackets around so it would go on the Rops. These dealers should know what they are doing. Doesn’t make me feel good about guys servicing my machine when they can’t get brackets on a roof right.
Reactions: Mudwing
Russ989
Russ989
22,642
147,257
@HondaTech is correct, your outside clamp and brackets are wrong all together. This is what they should look like before putting them on the roof.
13577663 F29A 4F79 8EEF 5F7D46C89D2D
Reactions: Mudwing
tigerj
tigerj
Louisiana
amen.
i won't be using them for service to say the least.
will drive over 2hrs for excellent service any day of the week.
thank you all for helping. i have some neurological issues that can confuse me from time to time (a little slower these days) but knew something just wasn't quite right when i saw my nets
Reactions: Mudwing and Russ989
tigerj
tigerj
Louisiana
ok will fix the two outside clamps only
then proceed with windshield install if center roll bar and rear roll bar look good to you all
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Sounds good
Reactions: tigerj
Russ989
Russ989
22,642
147,257
amen.
You are welcome, we pride ourselves on being the best forum around. Good luck.
Reactions: Mudwing and tigerj
HondaTech
Your head would spin if you knew all the stuff I've fixed and had Honda pay me to fix that other "dealers" have assembled and sold.
Russ989
Russ989
22,642
147,257
I bet!
Reactions: Mudwing
tigerj
tigerj
Louisiana
russ your helpful video 2 center brackets face forward (1st pic)
mine seem to face towards the driver
your outside brackets look like mine and face to driver
A7FD9245 6828 4485 9638 69532A8FB9D7 4A59DC76 DCEE 4C9D 9786 E5DF5925CC23
Reactions: Russ989
tigerj
tigerj
Louisiana
SE La., Kentwood at Ms state line, I-55.
awesome!
my cousin has 1 as well and we ride near woodville, ms
he'll be joining the forum soon
he got his in brookhaven, i believe that's where i'll trailer mine for service unless you have found a closer place you like
we definitely all need to meetup sometime
Reactions: BigOL3 and Russ989
Russ989
Russ989
22,642
147,257
View attachment 169507 View attachment 169508
My center clamps are correct but the brackets are backwards. Your center clamps and brackets are correct, no change necessary. Your outer clamps and brackets are wrong. You need to take yours off and line it up like that pic I posted earlier from the Honda instructions.
Reactions: tigerj
tigerj
tigerj
Louisiana
will do
thanks for clarification
Reactions: Russ989
BigOL3
BigOL3
2,997
8,920
awesome!
I bought mine in Brookhaven also. Woodville area has some good hills. I would love to GTG for a good ride in that area if it is permissible. Give me a heads-up if that is something that is possible.
tigerj
tigerj
Louisiana
indeed, private property:)
Reactions: BigOL3
tigerj
tigerj
Louisiana
will need some encouragement regarding said hills! i haven't cared for them since a child and there's one climb and descent quite steep i always steer clear!
definitely want to see the p1000-5's at their best
i believe it all began one fateful morning turkey hunting with my father and falling on a hill and my gun went off...
downhill, pun intended, from there!
Reactions: Russ989 and BigOL3
