Honda Talon Bus Bar kit
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
Can anyone tell me where this is mounted on a 2023 Talon1000X-4?
I know one has been installed to power the winch. But I'm perhaps wanting to use more of its 300A capability.
1697820305376
Thanks in advance,
Pirate
Reactions: TxDoc
Scoop
Scoop
5,130
20,277
  3. Talon R LV
This picture would seem to indicate it would typically be installed in front of the driver under the hood cowl
1697821307976
Reactions: TxDoc
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
Thanks. I have the Honda Fuse Block the dealer installed. So it's a little crowded under the hood/cowl.
I'll take another look!
Thanks!
Pirate
Reactions: TxDoc
Nevada Notch
Nevada Notch
Carson City
Good find.
A couple years ago I contemplated using one of those for all of my electrical connections such as light bar, mirror lights, stereo and whips. Instead I used those exact 2 lower mounting holes to mount a 4 relay/fuse panel.
I looked forever when I first got my Talon trying to figure out exactly how the bus bar mounted.
Rand
Scoop
Scoop
5,130
20,277
  3. Talon R LV
Good find.
Rand
I'm a big fan of the Auxbeam 8 gang boxes. Easy to install and way easy to add new accessories down the road. My 3D printed mount for the control head makes it look factory.
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
One thing. It's pretty easy to remove the Upper Dash, which provides full access to the Bus Bar location.
I put down a deposit, over the phone, for the Talon after wife found it by calling around three states...
She said: "Now, choose the Honda accessories you want and have the info with you when we go pay for it."
My list included the S&B Particle Separator and the Honda/Warn winch. Both required the Honda Fuse Box and
the Bus Bar.
They were installed by a Dealer Service Tech. So this is why I "chose" them.
I like the fact that the Bus Bar is designed to have the winch Contactor mounted on the right end of it. Then three
(+) and three (-) posts on it.
The Red (+) cable running from the battery enclosure to the Bus Bar location is the power source. A ground wire needs to be run from the Bus Bar to a shiny metal frame location.
Dealer ran a Ground (-) cable from the Bus Bar to this location, just above the overflow bottle:
1702137947532
I have added a Blue Sea Systems fuse block to provide for "always Hot" accessories. That's another story.
Pirate
5,406
24,778
While this is beautifully done,
1697827973779 png
it eliminates the possibility of two popular aftermarket accessories - 1. Easy second battery installation. I don't care for this kit because batteries don't like heat and this kit puts it directly behind the radiator, but it is popular. 2. The EMP under hood storage compartment, where I keep my kinetic rope, soft shackles, and tree saver strap. Be sure to drill a hole or two in the bottom or it'll fill with water. DAMHIK :oops:
Emp underhood storage box honda talon 1000 82
Reactions: Coeus
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
This is why my big 'ol second battery is mounted in the foot well of the passenger side rear set.
With the Tusk rear seat bed plates installed, the footwell is covered, so a perfect place for the NAPA Deep Cycle battery.
On the Tusk plates will be a good size, custom built aluminum cargo box. Add in the Honda Cargo box...nothing will be exposed to dust and water this time around!
Pirate
  • Love
Reactions: CID and Coeus
DRZRon1
DRZRon1
1,198
3,859
PA
Pirate
Omg - he doesn’t have the second battery the same age, style, type, manufacturer - it will now only last for the life of the machine
Reactions: Hondasxs
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
Yes, but I bought the battery to start a 1947 Austin-Western grader and get it on the lowboy. Brought it home, parked on the lower 40 as yard art and removed the battery.
So, might as well put it to use.
Pirate
Reactions: Backwoods and CID
DRZRon1
DRZRon1
1,198
3,859
PA
Pirate
Yep - it will be just fine, !!!
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
Haven't had time to spend on this post. But,
I've installed a TRUE Battery Isolator between the two batteries. This will/should keep both batteries charged will the engine is running. But what about when it's parked, overnight or for a few weeks?
I really like the NOCO Battery Maintainer. It has a display on the front to tell you what it's doing. Much better than the old Battery Tender.
Does one then connect the NOCO to the OEM battery and it should charge the second battery? How will that work, I dunno.
So I did a little research and found that NOCO makes Battery Maintainer that charges and maintains two batteries.
It's the NOCO genius GEN 5x2. The five is for five amp charging capability. The two is for two batteries.
Here's mine after installation:
1702238313350
Both are mounted to the back of the cab, behind the Driver side rear seat. Note: I've removed the rear seats as part of converting the back seat area to a cargo area. The two batteries are kept fully charged when the NOCO is plugged in.
Thus, I'm able to keep both batteries charged whether riding or not.
Pirate
5,406
24,778
Neat setup, Pirate. 👍
For the curious, you can hook a battery charger/tender to either battery if you're running a True Isolator. Once the battery that you're hooked to reaches 13.x volts, the isolator will connect the two batteries, charging both from that point on. IOW - the True Isolator is ambidextrous and will work both ways.
What it won't do is give you the condition of both batteries like Pirate's setup does.
Maybe @Hondasxs (or anyone who knows) can tell us (me) what that switching voltage is, I forgot. 😢
Scoop
Scoop
5,130
20,277
  3. Talon R LV
I asked them back in JAN 2022:
5,406
24,778
Pirate88
Pirate88
36
50
Southern Colorado
  1. Talon X4 LV
CID,
That was my reasoning for the dual NOCO. After a hard day of riding and using both batteries...I don't have to wait for Battery 1 to be fully charged before Battery 2 begins charging. Probably doesn't amount to much. But I did it anyway.
Pirate
Scoop
Scoop
5,130
20,277
  3. Talon R LV
CID,
Pirate
After a hard day of *riding*, battery 1 will already be fully charged provided that your charging system and battery are in good shape
The main reason people use isolators is to avoid a drained primary due to extended use of things like winches (inc. plowing) or running radios and lights when the vehicle isn't running.
