P1000 How bad is the cab heat problem, really?
Recurveman
14
27
Gilbert Arizona
Oh just think of it as a seat warmer. You pay thousands of dollars for the upgrade seat warmers in new trucks and this one is FREE!!!!
On a serious note. I do think it gets a bit toasty when outside temps are above 75 degrees or so. I also think it might be a bit hotter when you have the bed down instead of the seats up. I think the seats up lets the heat leave a bit better.
Seadonist
Seadonist
380
1,117
New Orleans
Front and middle front seat passengers will be uncomfortably hot do the hot seat when working the machine moderately. Installing reflective foil under seat and wrapped up the back will solve 90% of the problem. The other 10% can be solved with a fan under seat blowing to back to put more airflow over the exhaust system. There will still be some heat coming through the shifter and brake light spring hole but I can live with that. For rear passenger side riders, install the heat shielding under the floor boards.
During the warmer months down here in south MS/ LA, I use my machine for working on the deer lease and most times I’m driving at very slow speeds so the engine heats up fast and my radiator fan runs constantly. I put a bilge fan under the front seat not so much to relieve heat for passengers but to suck heat out of the engine bay to take a little stress off of my radiator fan. It helps tremendously for that purpose. I couldn’t care less about the cab heat for passengers
StewB
StewB
748
3,479
Agree about the passengers. If they don' like it, they can buy their own machine.
