P500 How hard is it to change P500 fuel pump?
Steve00
Steve00
64
91
Florida
Shop wants $300 to change a fuel pump not including Parts how hard is it how to replace the fuel pump in the P5? I looked online I couldn't find directions how to use or photos or where it even is yeah I know I should probably buy a shop manual what tapped out on other repairs it doesn't seem like it could be a complicated project I would buy the whole assembly. Any help would be appreciated
Reactions: rtn001
Wallace
Wallace
Well that didn't go as planned
2,813
15,101
Lonoke Arkansas
I wouldn't think it could be to hard. I think @nctrailboss has changed out one. You might reach out to him.
Reactions: rtn001
ehart814
ehart814
1,653
3,631
NWPA
If I remember right, you remove the plastic under the seat like you need to when you change the oil filter. You can see the top of the tank and fuel pump. I can't remember exactly but I seem to think it appears to be fairly simple. Once you get access to the top of the fuel tank, you just unbolt the top flange, unhook wires, unhook fuel lines and the pump/sender assembly should just lift right out
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,790
183,384
Grand Junction, CO
try this @Steve00 , a couple of pages are upside down from scanning so just print this. the way it scanned and using snippy tool I couldn't rotate, hope this helps.
  • P5 Fuel Pump removal.pdf
Reactions: rtn001 and trigger
Steve00
Steve00
64
91
Florida
Wow this is amazing you went so much out of your way I really appreciate this thank. I'm going to rotate the photos clean them up and cropped them and repost them on here for other people to get help thank you so much one last thing wheres the fuel pump located I think someone on here said it was under a seat the passenger seat ?
To get to the fuel pump do I have to take anything else apart to get to it other than the cover
Reactions: Mudwing
Steve00
Steve00
64
91
Florida
Okay attached are all the images of how to install a fuel pump Pioneer 500 from 2015 to 2018 part numbers and schematics from Partzilla not a bad deal might as well get the whole assembly just to make it easier schematics number 2 is the whole assembly which includes the number one all these images are for someone else like me that happened to stumble by this post I still need to know where the fuel pump located I'm not at my garage I think it's under the seat I hope you don't have to remove the fuel tank this is a great form and all you guys have been really helpful🙏🙏👍
Screenshot 20200219 112927 Adobe Acrobat Screenshot 20200219 112953 Adobe Acrobat 20200219 113341 20200219 113324 Screenshot 20200219 114254 Chrome Screenshot 20200219 113703 Chrome 20200219 114104
Reactions: rtn001 and Mudwing
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,790
183,384
Grand Junction, CO
I think you can get to it by removing the rear side cover, see attachment.
  • Fuel Pump Rear Side Cover Removal.pdf
Reactions: rtn001
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,790
183,384
Grand Junction, CO
Here is a cleaned up removal PDF to replace the other one I sent earlier @Steve00 I had to take apart my service manual put now I can scan individual pages.
  • Pioneer 500 Fuel Removal.Rev.pdf
Reactions: rtn001
