P1000 How slow is low?
trackerkelpie
trackerkelpie
12
Can some of you lucky P1000 owners tell me what the slowest speed your machine will comfortably cruise up an incline without slipping the clutch. I was out educating weaner cattle this morning in a less than suitable Viking which can only cruise above 5 kms(3 mph) which is too fast. If this is an issue does anyone know if the clutch engagement speed is adjustable?
I believe the Pioneer can move at any speed I know my 700 would creep along if I needed it to, and it was a standard automotive type transmission. The DCT is what you get in high end performance cars, and does not work the same as a CVT. A CVT uses the clutch because the belt is not supposed to slip at all on a CVT its can absorb some shock as its rubber but if it slips it burns up. Which is why water and contaminates are so bad for CVT equipped SXSs.
Reactions: bobbyhill
trackerkelpie
trackerkelpie
12
Thanks Ohana, I have a lot of experience with CVT clutches as well as wet clutches but not DCT. Is the engagement a positive off-on type of is it more like a torque converter where slipping just heats up the oil?
Think manual trans but electronically controlled. See how smooth the DCT is in the acceleration video? The electronics control the clutch engagement and gear speed.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Duel clutch is the key to smooth!!
Reactions: CumminsPusher
hondabob
1,261
5,004
Prescott Valley, AZ
The 700 may be better with the torque converter and can let you drive under 1 mph all you want. You can inch along. Some one needs to check the take off rpm on the 1000 to see when it moves. There will be a point where you could hold it where the clutch slips but that may be under 1 or 2 mph in low range.
Very true
trackerkelpie
trackerkelpie
12
Yes we tested the 700 but it was unsuitable in other ways,ie ground clearance, suspension, and lack of turf mode etc. The torque converter seemed to be struggling at low speeds when climbing steep terrain as well.
Thanks for your input.
trackerkelpie
trackerkelpie
12
I ran mine very slow last weekend on our cattle farm. I would guess 1-3 mph and it did completely fine.
So do you think the clutch for first gear is fully engaged at 1 mph?
nbomar
nbomar
4,416
17,854
Springdale, AR
Felt fine to me. It's basically on or off. It's not like my Polaris was with the spin up clutch.
N
Ned
241
183
West Kentucky
I find that I am often cruising very slowly, under 5 mph. Cause the manual says that if you are driving under I think 5 or 6 for prolonged times, low should be used. I do, but I love loping along at about 5 or 6, it's so quiet and peaceful I can look for game or fish jumping or even good fire wood. I have taken a couple of slow runs up pretty steep grades from the start in both low and high. High gear wants you to lay on the pedal and get moving, low is just fine walking up the hill slowly. Being new I will run more and more testing. I really do love this machine.
Reactions: trackerkelpie
nbomar
nbomar
4,416
17,854
Springdale, AR
I have only used low on my machine so that is worth noting.
WyomingRancher
WyomingRancher
11
31
Just got done feeding grain to weaned heifer calves this morning. This machine is unreal quiet and will go as slow as a guy would want.
66,869
Today I was able to maintain 3 mph in low with the foot on the gas.
BUT in High it did even better as idle would push it along at a steady 3-4mph after a slight start.
Between 1 and 2 mph the throttle control could not decide if I wanted it to stop or go. Made it jerky ride.
trackerkelpie
trackerkelpie
12
Thanks Hondasxs. I really appreciate this feedback. It looks as if the clutch engagement speed is a little high for my purposes so I need to contact Honda tech to find out if this is something that can be adjusted.
66,869
I could not imagine needing to go slower then that. It was about to drive me crazy testing it for you. hahah. But to his, his own!
RPM's were really low in high gear. I will get some video tomorrow if I remember.
No problem.
sajnaj
sajnaj
171
146
clinton indiana
it can not be adjusted there is a centrifugal clutch and change clutch. and im doubtful if there is a way to adjust the idle speed on this machine with fuel injection without a programmer. the centrifugal clutch is what the deciding factor is and its set to a certain rpm where it begins to engage. the change clutch is disengaged quickly through gear changes.
trackerkelpie
trackerkelpie
12
No problem.
Thanks @Hondasxs and @sajnaj for your replies.
Imagine this. 1000 hd of Brahman weaners moving through a series of paddocks for 10 miles at say 3 kms per hour (1.88 mph). It takes just under 5.5 hrs with an operator behind and to the side and dogs steering the sides. If the SXS only engages at 3 mph that necessitates 5.5 hrs of start/stop operation which is extremely tedious and very hard on the clutch, if, however the clutch is fully engaged at 1 mph then it is possible to cruise along at the correct speed using throttle to speed up and slow down without the necessity to stop. Also much of the terrain is very rough with fallen timber, tussock grasses and melon holes making a 3- 3.5 mph traverse extremely rough.
Sajnaj, you mentioned a programmer, what is it and is it an option to achieve the result I am looking for?
F
Fullthrottle
164
84
Thanks HSXS and Snaj for your replies.
Sounds like you need a horse. Never seen any sxs that couldnt follow behind a herd of cattle.
Reactions: gatorguy
