I thought the same thing, it makes no sense!Not sure I understand the need to remove the rear seat bottoms.
Otherwise nice video.
Cause she doesn't know how to fold them upNot necessary.
Very easy kneeling from the front seat.
Maybe 10 minutes but I was having a good day.
But I appreciate the video all the same.
Scratches her name off the list for a potential wife! 😂Cause she doesn't know how to fold them up
LOL ....... I was thinking the same thing. Then I was thinking ....... would that have made it easier, with more room??? Well ..... NO.Not sure I understand the need to remove the rear seat bottoms.
$37.xx at RMI changed my $44.00 air filter today. The two gaskets that came with it kicked my tail end. I ended up using a dab of 3-M adhesive and some steel spring clips to hold while drying. The smaller o-ring for the filter itself, caused the filter to kick up on the end away from the screw. I think the cover will hold it in place. I know there is bound to be a better price on an air filter.
I agree.If that filter is dirty, I should start buying used filters from Superatv because mine have never looked that nice
If you do the under hood snorkel and use a pre-filter, they last a really long time. I am snorkeled through the hood with an oiled pre-filter and my filter looked great after 3 dusty days at RRB. This is mine after 875 milesI changed my $44.00 air filter today. The two gaskets that came with it kicked my tail end. I ended up using a dab of 3-M adhesive and some steel spring clips to hold while drying. The smaller o-ring for the filter itself, caused the filter to kick up on the end away from the screw. I think the cover will hold it in place. I know there is bound to be a better price on an air filter.
That's fantastic. I may have to snorkel mine.If you do the under hood snorkel and use a pre-filter, they last a really long time. I am snorkeled through the hood with an oiled pre-filter and my filter looked great after 3 dusty days at RRB. This is mine after 875 miles
I run a Filter Wears cover over an oiled Spectre filter. I know not everyone likes the through the hood snorkel, but it does what it needs to with very minimal effort. If you do the under hood snorkel, I think there's some stuff called Frog skin you can stretch over the opening that acts like a filter. Or you may be able to find an actual oil-based filter that will fit under the hood.That's fantastic. I may have to snorkel mine.
