P1000 How to get wrench on castle nut?
MikeyXX
MikeyXX
122
227
Oro-Medonte, Ontario, Can
The front lower ball joint. I can't get a wrench in there to tighten that nut. Spinning ball isn't an issue, just can't get a socket, or wrench over the nut due to the walls.
Reactions: Lady01 and TxDoc
JenElio
JenElio
81,467
710,997
Loxahatchee, florida
Should be able to use a open end wrench no problem. Remove the tie rod for better access
Reactions: Homer and Lady01
280,835
Remove the wheel
Remove the hub
Take out bottom shock bolt
Take out lower arm mount bolts
Lift lower arm up and out until axle end retracts through wheel bearing.
Spin lower arm 180 degrees, Remove lower ball joint castle nut with regular socket.
20210730 172543
Note that lower ball joint is super tight, recommend at least a 12 ton hydraulic press to remove it. Just replaced all of mine last week.
20210729 172022
JenElio
JenElio
81,467
710,997
I know this is an incredibly late reply but thanks. Now my problem is that the ball joint is just spinning when I'm trying to tighten it up. Any suggestions for that?
Damn bro 🤔.....you been fighting that ball joint for 2 years?????
JenElio
JenElio
81,467
710,997
What's spinning, the threaded end when you tighten the nut or the actual ball joint spins in the arm? Cause........😬
POIDH!!
Reactions: TimG and Smitty335
