Howdy from Georgia
PioDawg
PioDawg
10
27
Just purchased 2019 1000-5 LE and adding stuff. Wiring makes my head hurt not to mention I'm a perfectionist and want it all neat and clean. I have the duel battery isolater, powerbass sound bar, superwinch 6000 and Tribal whips. Is it necessary to add a stinger to run accessory fuse box? What might be a better way if not. Thanks in advance look forward to being an addition to the group.
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
Welcome from southern Ohio! I do not believe it is necessary to run the solenoid, but it is a good safeguard for your system. It’s also necessary if you want to run a 3 way switch so you can run your accessories with your machine turned off. Hope this helps. Also if you struggle with a trailer check out mad ramps.
#NTC
BamaBoundSteve
BamaBoundSteve
111
75
S.E. Alabama
Welcome from SE Bama!
