So I put the first 125 miles on my new Talon X this weekend. The riding was mostly tight trails and rough slow speed exposed rock roads (I’ll make a separate post about my overall impressions a little later). To get to the trails, there was typically 10-12 miles of twisty gravel roads allowing for some higher speed driving. The Talon was great fun on these roads, except for the ridiculously loud high pitched howl from the trans/gear box! It was uncomfortably loud at anything over 30 mph or so. I was running in High range and it was almost unbearable in either acceleration or deceleration, as well as most of the time at a steady cruise. It was so loud my wife let go of the grab bar to plug yer ears. Is this normal? I have a hard time believing Honda Put out a machine with a drivetrain that makes that kind of noise! I checked all the fluids and all looked fine. The howl is present at lower speeds/rpm also, but not nearly as bad as at higher speeds.
Anyone else experience this? I’ve read and watched all the reviews where they talk about how quiet the Talon is when compared to other brand SXS!
