i-4wd Cable Adjustment
RLMurphy
New Brunswick Canada
My P1000-5 Trail has i-4wd and sometimes it takes a long time to go into 4wd after moving the shifter, wondering if anyone has details on adjusting the cable at the front diff?
Reactions: TxDoc and Smitty335
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
Cable adjust is right front diff.
Small adjustments go a long way.
After small adjustment, my I4 is almost instantaneous, in and out and on the dash.
Not to be the dick.., by becoming a lifetime or supporting member, you will get you an electronic copy of the service manual..
Mark in Northern Iowa
501
2,217
Floyd County, Iowa
kramnella.wixsite.com
And then along with what they said ☝️ ☝️ ☝️
Page 50 in your Owners Manual.
"After changing the drive mode, drive several yards, make right and
left turns, and make sure the indicators work properly."
Drive mode changing
Have a good day
906UP
906UP
15,066
143,202
da Yoop
Here's a good video on how to adjust the cables, I don't know if the i4wd P1K's are the same
RLMurphy
Have a good day
Thanks, I did miss that in the manual. Checked the cable adjuster earlier today and it looks good. I will give the wheel left-right manoeuvres a try next time I’m out.
116,574
Thats not being a Dick. Your pointing out useful info that he may otherwise had never known.
Only the woke sensitive crowd would think your being a dick and take it as offensive ;)
