S Shako1921 New Member May 23, 2024 18 9 3 tbilsii Ownership Talon R Jan 25, 2025 #1 hello i have made DTC Readout i see there are 3 errors 3-6 ; 6-6 ; 12-1 can someone give me an advise what can i check ? Reactions: ChadD
Fatsquatch Approved Member Lifetime Member Supporting Member Jan 30, 2018 121,609 1,013,744 113 Hidden Jan 25, 2025 #2 Shako1921 said: hello i have made DTC Readout i see there are 3 errors 3-6 ; 6-6 ; 12-1 can someone give me an advise what can i check ? Click to expand... A $15 supporting membership or $50 lifetime membership will get you access to the service manual where you can look those codes up. Reactions: ChadD, JNo323 and Smitty335
Hello_Darkness Well-Known Member Jun 6, 2024 683 2,767 93 Just to the right of nowhere Ownership Do not currently own Jan 25, 2025 #3 Code 3-6 Rear Right Out Solenoid valve failure Code 12-1 Front Right Regulator Solenoid/Current Feedback circuit Code 6-6 does not exist Code 3-6 and 12-1 point towards a failed i-4wd modulator Reactions: ChadD, 1HasBeen and JNo323
