Congrats on your purchase! Looks like it is set up real nice! So far, it sounds as though the guys here have it all covered.... just enjoy the ride!!!!
If your not jumping or crazy hard just take those arms off and use a torch to get them straightened. Add a piece of angle iron welded to it for some stiffness. Use those tires up while you decide what you want.I appreciate the help.
Addressing some of the questions:
Other than uneven tire wear and appearance, is there any other issue with the negative camber on the front wheels?
- No wheel spacers in the front, but the back has what looks like 2” spacers, presumably to offset moving to the same size tires on front and back.
- The wheels don’t rub except in very tight turns. Previous owner mentioned this and said if he could do it again, he’d have gone with 28’s instead.
For replacing the “A” arms on both sides, what is recommended? OEM? Aftermarket?
If/when I replace them, will I need any other parts?
What are the best web sites people generally use here for OEM Honda parts for Pioneers?
As for the shocks, I assume the stock OEM ones in there are “OK”. If I were to replace them on a budget, what are some recommended ones (not wanting to break the bank – on a budget)?
ok stock to meI went outside and looked at it while parked in the garage. It doesn't look nearly as exaggerated in the earlier photo, but it still does have a visible negative camber to it; looks like a bit more on the passenger side front. I looked at the ball joints and hardware around the wheels and nothing stood out to me as worn, broken or an issue.
Passenger side front wheel area:
Driver side front wheel area:
Awesome! Glad to hear it.Ok, she's all put back together and the camber looks normal now.
nothing special needed here. Just a tape measure and a couple wrenches.I do need to do an alignment as it pulls to the left; hopefully I can avoid having to buy more stuff to do that.
Keep a close eye on that wallet. They tend to develope big holes and leak money profusely. 🤣🤣🤣Ah, your wallet is just warming up.
Looking good.
Those are some awesome upgrades! I have a 2021 Pioneer 1000-3 with stock shocks and thinking about going with Fox front and back. The model that I am looking at is 08Z70-HL4-F50 and 08Z71-HL4-F50. How much of a difference in the ride are the new shocks that you have?My wallet's a bit lighter. I've added a few things in the last 6 weeks since the Seizmik bed extender:
RotoPax fuel cans and mounts.
Fox shocks front and rear suspension
Color-matched shifter gate cover w/gaskets
Throttle-Maxx pedal
Whip mount
Considerable amount of DESI heat-shielding under front seat and rear flooring
Rear doors storage modification
Storage door under the driver's seat
Fixed the Subwoofer and amp (was a bad amp) on AudioFormz roof (this thing sounds NICE!)
Only things left for me to add are a lighted whip and maybe some rock lights. Gotta research the best ones.
Thanks for the reply, I'll get a set!Those are some awesome upgrades! I have a 2021 Pioneer 1000-3 with stock shocks and thinking about going with Fox front and back. The model that I am looking at is 08Z70-HL4-F50 and 08Z71-HL4-F50. How much of a difference in the ride are the new shocks that you have?
Thanks
