2017 1000/3 need help! Hit a stump front passenger axle popped out and torn the frame tab. Front diff fluid ran out of axle hosing. I lined up the front end welded the torn part up, added gussets to strengthen. Slid the axle back in and buttoned it back up. That’s when I noticed the axle wasn’t seating up all the way. After hours of frustration I come to the forum wizards asking for help. At this point I have managed to get the axle stuck on the differential side and it will not come loose. How do I get the axle out of the differential. After yanking on the axle has separated. Being the genius that I am and not knowing any better I cut t,he boot off both ends and now the ring end of the axle will not come out. I ordered new Rhino 2.0 axles for it nut I need help in getting the old axle end from the differential. Please help! Also is there anything else I will need to get things back together other than the axles. This is driving me nuts and I really need my machine. I do not ride mud,water , or bog it out at all. I use my machine to operate my small farm and really need help getting this thing back together. Thanks!
