I think all reputable brand names make good ones. As far as tie rods go I think oe is best. I would rather break a tie rod on trail than a rack. Black Friday is coming and I bet @SuperATV has some sales.So got a popping sound comming from the rack when turning I hear a lot of people swap the rack but which one is best and which tie rod ends are best?
RB3 off-road.I hear a lot of people swap the rack but which one is best
And the 2022 version will fit just fine? And when it comes to the rack I see on there site there is two different gear options which one should I use ?Might be a good idea to look closely at the upper control arm bushings. My 2016 had a "pop" on the driver side and it seemed like it was from the rack, but upon closer inspectiopn the upper arm was loose and shifting , causing a pop. Took it apart and the upper shaft and bushings were worn out. I made some new bushings out of DELRIN and resurfaced the shaft. Also drilled the upper arms for grease fittings. My pop is gone. If you do replace the rack, You canalso update the tie rods to the 2022 version. Stronger than the 2016-2021 versions.
Cv shafts are brand new rhino 2.0 just installedI think all reputable brand names make good ones. As far as tie rods go I think oe is best. I would rather break a tie rod on trail than a rack. Black Friday is coming and I bet @SuperATV has some sales.
Also double triple check that your noise is not cv shafts.
Is the rack hard to change?RB3 off-road.
there also a vender
Never done one but many buddys have had to And said it wasnt fun. @TripleBIs the rack hard to change?
It's not that bad. I had a problem of getting one nut started myself. I couldn't get anything to wedge in there to hold the bolt in place to start the nut.Never done one but many buddys have had to Nd waxh one said it wasnt fun. @TripleB
Yes they will fit. I swapped my over months ago.And the 2022 version will fit just fine? And when it comes to the rack I see on there site there is two different gear options which one should I use ?
Your machine looks like a LE? I thought superatv didn't make axles for the LE?Cv shafts are brand new rhino 2.0 just installed
Just came out a few weeks ago. 2.0’sYour machine looks like a LE? I thought superatv didn't make axles for the LE?
Yep just looked up and came back to comment and you beat me to it lolJust came out a few weeks ago. 2.0’s
In that case, I still wouldn't rule out the cv popping.Just came out a few weeks ago. 2.0’s
Thats ok, we all get Plumber syndrome at times 🤣Yep just looked up and came back to comment and you beat me to it lol
Yup, if i was him id have a buddy stand next to it while driving to see if its the axel. Easier fixIn that case, I still wouldn't rule out the cv popping.
I've had the same popping sound from the bushings being wore out. He probably doesn't have the superatv arms and I've never heard of someone wearing out the stock a-arm bushings. I've also had a popping sound coming from the fox shock bushings being wore out.Might be a good idea to look closely at the upper control arm bushings. My 2016 had a "pop" on the driver side and it seemed like it was from the rack, but upon closer inspectiopn the upper arm was loose and shifting , causing a pop. Took it apart and the upper shaft and bushings were worn out. I made some new bushings out of DELRIN and resurfaced the shaft. Also drilled the upper arms for grease fittings. My pop is gone. If you do replace the rack, You canalso update the tie rods to the 2022 version. Stronger than the 2016-2021 versions.
🤦♂️It's not that bad. I had a problem of getting one nut......... Wasted hours of my life trying to get that last nut before I called someone to help.
I was just going by his little pic. I didn't know heIf I recall correctly, isn't @Bigmanlittlebuggy up on 35s or something with portals and all? If so, his odds of the steering box being the problem becomes more likely.
But to the rest of the guy's points here, a front end noise can be a lot of things and can mislead you.
Get it up on stands and wiggle everything.
