P1000 Idle noise
William
William
1,442
2,887
Flowood MS
What do y’all think this noise is? It goes away with a tad of throttle. Sounds kind of like a cam chain... Doesn’t sound like valves to me. Normal?
Reactions: Isaiah
60,987
Almost sounds like something hitting the heat shield.
HondaTech
Its hard to tell, but I've heard some noise before in 1000s that I've attributed to the ball inside the valve cover for the crankcase breather.
This sounds louder, without hearing it in person, id truck it back to the dealer and see what they say.
William
William
1,442
2,887
Flowood MS
With the bed down, It’s not that loud. I’m going to do the first service then I may take it back if I don’t hear an improvement.
William
William
1,442
2,887
Flowood MS
@JTW Is this what yours sounded like.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Take it back to the dealer sounds like something' Loose internal. It could be ex ternal though Because I'm just listening to a video
William
William
1,442
2,887
Flowood MS
Just sent my dealer the video. He said it is normal. Just valve noise... Gonna stop by another dealer and let them listen.
William
William
1,442
2,887
Flowood MS
Well the other dealer wants to check it out... I’m just going to let them do the first service and check out the noise... Also check valves. Dropping it off Saturday morning...
William
William
1,442
2,887
Flowood MS
It has now started doing it constantly...
William
William
1,442
2,887
Flowood MS
The noise has evolved... I think something is coming apart...
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
The sound don't come across very well, but it sounds like my Pioneer when the cam chain tensioner failed.
The noise started by coming and going rev it up and it would go away, it didn't do that long until it got noisier and wouldn't go away.
Now the good news is it's cheap and easy to fix or check.
Take the plastic cover off under the bed that you would to access the oil fill plug. Two bolts hold the tensioner in a new one is like $60.00 if it ok reinstall it.
If it is good it will extend all the way out and you will need to take a bolt/cap off and using a small screw driver to wind it back in to reinstall, if is bad you can push in and it will stay.
Reactions: William and MMW
William
William
1,442
2,887
Flowood MS
That’s the kind of answer I was waiting on.. It’s either that or valves. I drop it off in the morning. Hopefully it’s fixed by the takeover.
Reactions: GPR1500SC
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
It is not your valves if it gets quieter when you rev it up they just getting louder right away.
Half an hour should easily change the tensioner
Reactions: William
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Similar.. only mine doesn’t do it at idle. There’s a rpm range where mine rattles
There is a little check ball in the breather under the valve cover you may be able to hear rattle if the engines was vibrating just right in a given condition?
Reactions: William and JTW
So my final conclusion was that or the rubber motor vibration dampeners allowing some contact somewhere. I could grab the motor when I had the skid off and front up in the air building the new skid plates and could hear something contacting. I tightened the bolts through the mounts and it seemed to help. But it came back.
