Seems like I am plagued with weird electrical issues. 2016 P500
For the last year I have had an ignition issue and need some help figuring it out. If I let the machine sit up for a week or more and attempt to turn the key on, the lights on the display with come on then go off, on then off for several minutes. It will turn over however will not crank. I can try to cycle the key again usually with the same result. Usually I have to cycle the key on and off upwards of 20 times before the light will stay on and it will crank. Sometimes I can put it on the charger and it will crank. Once it stays on and starts, the problem will not show back up for several idle days.
Also sometimes the lights will stay on with the key in the off position, to which I have to disconnect the negative lead.
Diagnosis up to this point..
Cleaned every ground
Replaced the battery
Checked for parasitic draw, 0 amp draw with key off.
Changed the computer (different issue)
Changed the rectifier (different issue)
I am leaning towards ignition switch, but would love to hear your thoughts.
