P500 Ignition Gremlins
O
oakescharles
35
56
Seems like I am plagued with weird electrical issues. 2016 P500
For the last year I have had an ignition issue and need some help figuring it out. If I let the machine sit up for a week or more and attempt to turn the key on, the lights on the display with come on then go off, on then off for several minutes. It will turn over however will not crank. I can try to cycle the key again usually with the same result. Usually I have to cycle the key on and off upwards of 20 times before the light will stay on and it will crank. Sometimes I can put it on the charger and it will crank. Once it stays on and starts, the problem will not show back up for several idle days.
Also sometimes the lights will stay on with the key in the off position, to which I have to disconnect the negative lead.
Diagnosis up to this point..
Cleaned every ground
Replaced the battery
Checked for parasitic draw, 0 amp draw with key off.
Changed the computer (different issue)
Changed the rectifier (different issue)
I am leaning towards ignition switch, but would love to hear your thoughts.
105,313
How many miles?
@HondaTech might have something for u to check and qustions
906UP
906UP
13,006
121,233
da Yoop
Check the relays in the fuse panel/battery box. There's 4, all the same. One is your main relay, powers up the ecm & dash, another is for the fuel pump....I don't remember what the others are off the top of my head. Pull them out & check for corrosion, maybe swap them around and see if the problem moves to a different circuit.
O
oakescharles
35
56
Looks like you've got a relay sticking
Do you have a P5 shop manual?
The site has a download if you become a supporting member.
took them all out and some had a little corrosion. Clean them up and swapped them around. Hopefully this resolves the issue. :) Thanks for the insights!
906UP
906UP
13,006
121,233
da Yoop
Let us know. If it does "fix" the issue.....really it's just gonna move... I'd suggest new relays, one of them probably has moisture in it
O
oakescharles
35
56
Good suggestion on swapping fuses to see if problem moves. Id be interested in seeing if that was the issue.
Sent from my SM-A326U using Tapatalk
Started up perfectly this morning... I will continue to start it everyday to see if the problem returns. Cautiously optimistic
