Important oil change tips
pipefighter577
pipefighter577
120
Ohio
My mechanic told me to watch for this washer when I change my oil. He said it sticks to the filter and people throw it away with the old filter. Sure enough it was stuck to mine. He also said it will cause shift problems if not reinstalled. Just thought I'd share.
Jesytuzu
U7emuzaz
A8e3any6
U6yrege7
wyo700
wyo700
413
210
Did he tell you the symptoms of the shift problems. Not that mine is shifting weird and I sure hope I didn't throw mine away on my first oil change but just would like to know what shift problems would show.
W
waterboy1
10
That was a great tip changed my oil and sure enough the washer was stuck to the filter Thanks
wyo700
wyo700
413
210
Great now I'm starting to think my washer is gone. I can't remember I changed it quite a while ago. But my pioneer is shifting fine. So maybe not.
pipefighter577
pipefighter577
120
Ohio
He said the spring will work its way through the rubber on the filter and it causes a loss in pressure which results in shift problems if the washer wasn't replaced. He didn't specify what kind of shift problems just that they get brought in occasionally and that ends up being the problem.
68,145
Never tried, But it would seem you could check it without loosing any oil.
wyo700
wyo700
413
210
Took my oil filter out today. Sure enough washer was gone. But the spring did not seem to digging into the rubber part of the filter at all. I went to Home Depot and the only thing I could find for now was a 3/4 inch fiber washer. I had to make the hole a bit bigger with a file but I was able to get it on fine and don't see why it won't work. I never did notice any shift problems but now I can compare I guess.
wyo700
wyo700
413
210
O and I barely lost any oil when I checked not even enough I had to add any.
68,145
Good. Now everyone who wants can check there filter and want have to worry about loosing oil.
hurld
hurld
129
159
I did my first service this weekend. Thanks for the great tips guys. I raised the front end of my machine when I drained the old oil as I wanted to remove as much of the old oil as possible before adding mobile 1 4T 10w40 full synthetic motorcycle oil. The most time consuming part of the whole project was adding the new oil. Oh and it seems to shift much smoother with the synthetic oil.
T
tiogajoe
48
55
Anyone got the part number? I don't remember if I lost it or not? Better check and have a spare ready?
68,145
Heres the part # for the washer - 15414-300-000
Reactions: BVerhulst
wyo700
wyo700
413
210
Went to my local dealer today and to my surprise they had one so I'm good and back to normal now.
tincangob
tincangob
200
270
Central Wisconsin
My 2018 P3 shifted terrible when I first started driving it. I even took it back to the dealer once due to the problem, and they said it shifted normally. It had a significant clang with automatic engaged. I was very worried, but after putting some miles on it (maybe 100) the shifting smoothed out like I thought it should be. That's not to say the synthetic oil wouldn't improve it even more, but the new machines seem to need a break-in period. I may try the synthetic next time, and I'll be so pleased if it even makes it smoother than it is now. I just had my first oil change preformed by the dealer ($$$). I think they made a minor valve adjustment as part of the initial service. BTW, when shifting with the paddles it is very smooth, and I sure like the paddle option.
I find this forum very helpful, and you guys should be complimented for all the great input.
