P1000 Important Safety Recall October 2018
Rocket
Rocket
Rocket
283
946
Bullard, Texas
I just received in the mail a RECALL from Honda for “loose or mis-installed throttle body to engine connection”
322,690
Check the hose clamps going from air box to intake. Make sure they are tight and aligned correctly.
Reactions: BWAF and TimG
GerryC
GerryC
5
9
That's simple enough. However the recall notice states "loose to mis-installed throttle body-to-engine connection". That suggests something greater than the air box hose clamps.
Reactions: CumminsPusher
322,690
The wording makes it sound more complicated then it is. Just check to make sure the intake hoses are tight, super simple. There is a lot of movement on the engine during operation and if those clamps aren’t tight the hose can likely come off the intake.
322,690
can you show me a picture of where this is at.air box to intake clamps.
I don’t have pic handy someone else might but it’s clamps at the intake of the engine leading in from the airbox
Reactions: BWAF
6
68xlch
37
26
usa
thanks i will trace the hoses down and check the clamps. did you have to take any pannels off to do that
Reactions: BWAF
cwalton
cwalton
Who has more fun!
334
724
West Virginia
You do have to take the engine cover off. Not sure what else.
Reactions: BWAF
