Initial service
IDIOT
IDIOT
280
755
Kingman, Az.
I was looking at the owners manual to see what is required for the initial service and there is one thing that seems odd to me. It shows changing the motor oil, oil filter, and dct filter as part of the initial service but does not show the transmission oil being changed out. In fact it says the trans oil should be changed every 2 years regardless of the mileage and yet the capacity is only 1.35 qts. I just don't understand why it is not changed after breakin?
HondaTech
The subtrans oil is not being pumped anywhere, it's more like a transfer case.
Theres really no bearing surfaces just gears.
If it were mine I'd probbaly swap it at the first service.
Reneb3
46
24
Cross sc
The initial service has a Note 1 on the valve adjustment. Note 1 says as necessary if the engine is loud? Is this required if the engine is not loud? It's the difference between taking it to the dealer or just changing all the fluids. I don't notice any ticking. Plan on changing all the fluids myself and checking what needs checking.
Reactions: JACKAL
bigblueaz
bigblueaz
67
Arizona
I changed the trans oil too. I did not check the valves. Ill wait for a while to do that
HondaTech
Out of the multiple P1K I've serviced, none have needed a valve adjustment at first service.
Now the 700 and 500s are usually loose, not terrible but noticeably loose.
Reneb3
46
24
Cross sc
Thanks. That’s what I was looking for. The note implies it doesn’t need to be checked if it’s not noisy. Oil changes are easy and I like doing them. Could manage the valve adjustment but seems a lot for 100 miles on the machine. And my dealer is an hour away and would take 2 weeks to get to it.
all4sho
all4sho
30
61
Byron, Ga
What should the first service ballpark cost if you did everything with valve adjustment?
Reneb3
46
24
Cross sc
My dealer said $450. That’s why I asked about the valves. The oil and filters were about $90.
HondaTech
On a P1K we do 2.8 hours with a valve adjustment. Haven't done a Talon for anyone yet, except a buddy of our GM. Not sure what they charged him.
2.8 hours for us would be about $240 in labor plus parts. So both filters, 6 quarts of oil, washers and O-rings for the covers on a P1K. I think the Talon wanted final drives done @ first service as well.
ehart814
ehart814
1,653
3,631
NWPA
Slightly unrelated (my apologies), but what is the book time for a valve adjustment on a 500? My dealer quoted me $120-$150 over the phone and I feel like that isn’t going to be the price when I pick it up.
jasond
jasond
221
352
Indiana
I just did my 100 mile service for the engine oil and transmission oil. HOLY HELL these things hold a lot of oil compared to what I'm used to with my RZR XP1K, but that's not a bad thing.
Do yourself a favor and put a nest of shop towels in the skid plate underneath the engine/DCT filters. After you've put those there go ahead and add some more on top of those and you might contain the oil spillage lol. There are also 2 drain plugs for the engine oil (one is the oil pan and one is the oil tank) so make sure you drain each of them. The oil pan is a 17mm on the driver's side behind the transmission oil drain plug and the oil tank is more centered toward the rear of the machine and I think is a 13mm if I remember correctly.
Wednomo
Wednomo
11
9
Nampa Idaho
For the Honda Talon: How difficult would it have been for Honda to just simply state in the owners manual that the engine and DCT both share the same oil reservoir, when you pull the dipstick and check the oil, you are actually checking the engine and DCT oil. I'm a little frustrated as I put way more time in looking for this simple explanation that I share here with you. Also, I've pretty much read the owners manual from cover to cover and nowhere in the book have I been able to find the numbers for the engine and DCT filters. Again, why wouldn't this basic information be in the manual. Engine 15412-HP7-A01 DCT 15412-MGS-D21
Many thanks to this guy, he goes over how to change oil and filters and really help clear up a few things I wasn't understanding.
Reactions: stellarpod
Wednomo
Wednomo
11
9
Nampa Idaho
