P700m4 Installing full size auxiliary battery ?
You guys are killing me.. just when I have myself decided on a dual setup with the odessey you go and cast doubt on me.
The dual battery has its distinct advantages, do not be disconcerted from your incipient plan Grasshopper!
Reactions: JTW
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Just got off the phone with Dennis at DFNA. The guy that designed and manufacturers the True product. I will be adding the newest isolator SBI-15. After talking to him for 1/2 hour i think this is the best solution to my wants. I will just add a larger battery and installing one of his isolators. Only need 1wire between the main battery and the second battery with the isolator in series and then ground Auxiliary battery. Then i will use Auxiliary battery for all my extra devices. Only using OEM battery for factory installed devices.
Reactions: JTW and Tflynn
ckhenshaw4
176
81
I removed the factory battery, and went with a car battery under the seat for two main reasons. First I live in NH and it gets cold here in the winter and my 700 doesn't care for sitting in the unheated shed for a week sometimes then trying to start it. So I wanted the extra cold cranking amps to help here. Second reason is because while plowing last year with the heater being used intermittently, the stock battery/charging could not keep up.I only had to stop once for a few minutes to let it charge, but I have heat and I want to use it. I have a stereo that is wired (for now) to shut off with the key so I don't really have a need for any accessories to be used while its not running, so for me a second battery is not needed. Plus I like to keep things simple, a single battery with as few connections as possible so minimal chances of failure out on the trail.
sorry about the crappy pics, heres the under view
I put some tabs on three sides (the fourth side is right next to the plastic side panel) for some 1/8" aluminum sides for stick/heat shields.
I thought I had some pictures of the battery installed before I put the side back on but I guess I didn't. I can say that this upgrade is well worth. I haven't had any problems starting it in cold weather,in fact I find it starts a lot easier this year and for the few times I have plowed with it this year it seems to not run the battery down that much with the tunes blaring and heater on.
What heater are you using?
Sent from my Nexus 7 using Tapatalk
E
ezhoops
Tram, what larger battery did you go with?
Been running a Yellow Top under the drivers seat now for 2 years and no problems.
IMG 0185
I chatted with the guy that bought my 700-4 a while back, he is still running the Optima under the drivers seat I put there in late 2013. Its 4 years old now. Only had to replace brakes and perform reg scheduled maintenance, he was right at 3000miles back around August I think.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Not sure I sold the 700 a few months back. I would say a mid range size, not big but to the smallest. I did make sure it had the threaded connectors.
212,729
I'm going to redo that for you. I'm trying to do (3) five syllable words in that sentence. :D
Dual batteries assemblage has it's distinguishably predominance, do not be discountenanced from your preliminary aspirations. How's that?
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Hey ..
Like your battery setup in the 700.. My question is: What is the best way to extend the pos and neg cables over from the other side? How did you connect the stock pos and stock negative cables to your larger cables that you extended over to the other side, and how did you route them and what length..
Thanks
Thanks.
75” cables in 1” loom and zip tied clear of anything they could rub on. If you can get longer or make your own cables 75” is the SHORTEST I could use.
I used this bus blocking made sure the winch cable connector was sandwiched in between the battery feed and pioneer main cable so the bus block was barely carrying any capacity.
Standalone Stud-Type Junction Blocks
Reactions: Deluxe700
Reddragon
9
31
Sorry I am so late to this... haven't been on in a while...here is what I did on my P700-4.
Built a battery tray and U bolted it to the the two bars under drivers seat. Added a true-am-dual-battery-isolator.html between the two seat belt latches for the front seat. Added a dual battery voltage meter in the dash....ran my LED's and radio on the AUX battery... winch is still on factory battery. Hope this helps...haven't even put a battery tender on anything....and machine sits for maybe a month sometimes.
IMG 3982 IMG 3987 IMG 3993 IMG 3994 IMG 4008 IMG 3997
The Welder
Canada
Hello. This is my plan exactly. My 2019 700-4 deluxe despises the -40 C here in northern Alberta. I fab’d up a battery holder to go under the driver seat and purchased an AGM 600 CCA battery. Also changed oil to lightest winter oil from Honda. Also will add on a small oil pan heater. I’m really hoping this helps with cold starts. I’ve tried the prescribed method of starting to no avail. With a very weak booster it took 9 tries (in a cold unheated garage) over 20 tries with no booster. That original Honda battery is garbage. I’ll also try the NGK iridium plugs down the road.
Reactions: swsebek
The Welder
Canada
It’s installed finally. And works lol. I installed a Magna Charge brand group 47 AGM. a piece of rubber on the base of the bracket and where it bolts down to the structure. Lessen the vibration I hope. I also ran #2 wire for leads (It was the only wire in our shop which we use for stingers when welding, no issue with any current). Installed a marine breaker where the old GYZ16 Yuasa battery positive lead was and a negative terminal. Hooked up the battery blanket and the SAE trickle charger plug for Junior. Oh also installed a Canadian Polar pad 75 watts (2”x3”) on the right side of the oil pan. Hopefully this will cure the nasty nasty nasty cold Canadian winter starts. See what happens.
I
