Intake snorkel
BigOL3
BigOL3
2,994
8,919
Finally took time to modify intake and attach the hose for the snorkel. Will add a clamp at the base. It tucks in under dash nice and tight. 1214e951bc45fa972b31f81c455dddf88a95c0983ce30a025a1b986310c606fc
Sent from my SM-G965U using Tapatalk
K9Paco
K9Paco
625
2,180
Lake Charles, La
  1. Talon X LV
Gonna have to put something to keep that pre-filter in place. Can use some panty hose or I just used screws.
Bc1516a8eb8863d199a22f45db9973eb
BigOL3
BigOL3
2,994
8,919
Lol ..... I am the one that mentioned putting the screws in the tube. On this tube it has a big spring fitted inside of it.
Reactions: Lady01 and BWAF
A
AVDV
5
Florida
Better protection from water intrusion, and opens up more space under hood where air box was.
If you drive in water that is a waste of time.All you are doing is moving it back under the hood more. If you are going to snorkel it run it up along roll gage
BigOL3
BigOL3
2,994
8,919
NO, first it is raise slightly higher than original, so that is a benefit. Second, I have NO intention of playing submarine, I do not need it on the rollcage. If water is 'splashed up under the hood, it has less chance of getting into the hose in that location. By removing the old air box I have more room under hood.
A
AVDV
5
Florida
ok I see what you are saying, couple of curves help too.
Reactions: BWAF
K9Paco
K9Paco
625
2,180
Lake Charles, La
  1. Talon X LV
I bought that hose but I am having a very hard time getting it to fit... Any suggestions..
Use 3-4 screws. Mine don’t go all the way through but they go most of the way across.
Reactions: BWAF
Robobrainiac
Robobrainiac
2,464
8,600
I just ordered mine. I know this is an old thread but I have heard the wisest things get better with age. Does anyone use a pre filter on these?
Reactions: Remington
K9Paco
K9Paco
625
2,180
Lake Charles, La
  1. Talon X LV
Some do. I just used the stock one at the end of the hose.
Reactions: Robobrainiac
bumperm
bumperm
1,851
6,656
Gardnerville, NV
I bought the parts awhile back, including the filter. Decided not to use the rubber hose as there was really no room for it, and I didn't want to rearrange my "under hood" to gain and maybe 3 or 4 inches in intake altitude.
Filter
20211009 212022
